relocator kit from password jdm!
Old Jul 7, 2008 | 01:45 PM
CharleyCRX's Avatar
Default relocator kit from password jdm!
someone have it ?
mine didn't fit perfectly!
when the odyssey batterie is in! they don't fit
i will post pics tomorrow...
so i just ask what you did !?
Old Jul 8, 2008 | 08:10 AM
ph3ar's Avatar
Default Re: relocator kit from password jdm! (CharleyCRX)
I have ac, and it fit like a glove. Just remove the stock battery box. Well, I actually had to take my radiator out cuz of all my ac bs being in the way, and also had to take the top bolt out of my tow hook to get the box where i wanted it. Took me about an hour, but it definately fits right in there.
Old Jul 8, 2008 | 10:22 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: relocator kit from password jdm! (ph3ar)
If it doesn't fit perfectly file it till it fits.
Mine took a bit of trimming nothing major, but I'm happy with it esp at the sale I got at.
Can you get a pic exactly what isn't fitting and where?
Old Jul 14, 2008 | 02:28 AM
CharleyCRX's Avatar
Default Re: relocator kit from password jdm! (***$nyper)
Old Jul 14, 2008 | 06:14 AM
89s1's Avatar
i could solve that "problem" in 5 minutes with my dremel.
Old Jul 14, 2008 | 06:51 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
amen. elbow grease is what you need there sport.
Old Jul 14, 2008 | 08:31 AM
harmonator84's Avatar
Default Re: (ComeOnKip)
I think the point is that the guy didnt really want to modify the piece.
Old Jul 14, 2008 | 08:52 AM
blaak-crx's Avatar
Default Re: (harmonator84)
The battery is suppose to go under that lip (design to avoid having a top bracket support). If you want to remove the battery, you'll be forced to loosen the whole bracket. Did you compare the height dimensions of the battery versus the space between the top lip and bottom lip of the "box"?
Old Jul 14, 2008 | 10:28 AM
IT GUY's Avatar
Default Re: (blaak-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaak-crx &raquo;</TD></TR><TR><TD CLASS="quote">The battery is suppose to go under that lip (design to avoid having a top bracket support). If you want to remove the battery, you'll be forced to loosen the whole bracket.</TD></TR></TABLE>
exactly.
Old Jul 14, 2008 | 11:46 AM
wrestler72's Avatar
yea i opted to not go with the password crap. Fabbed one up for a fraction of the price and made it look alot better and the batter doesn't move at all.
Old Jul 14, 2008 | 11:55 AM
CRX EF 88's Avatar
Default Re: (wrestler72)
summit sells a bracket just like the password jdm one but its just made out of metal and so much cheaper. thats the one i got.
http://store.summitracing.com/...w=sku
Old Jul 14, 2008 | 04:23 PM
Crx Jimmy's Avatar
Default Re: (CRX EF 88)
Maybe the problem is the bracket is made for a pc680 and he has a pc680mj which has a metal jacket so its slightly taller because of the metal around the whole battery. so it doesnt fit under the lip
Old Jul 14, 2008 | 04:40 PM
crxmadness's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the problem is the bracket is made for a pc680 and he has a pc680mj which has a metal jacket so its slightly taller because of the metal around the whole battery. so it doesnt fit under the lip</TD></TR></TABLE>
Your correct! If you remove the metal jacktet it will fit in the bracket better.
Old Jul 14, 2008 | 04:48 PM
EFstyle's Avatar
Default Re: (crxmadness)
the metal sleeve is ment for if you put the battery anywhere inside the car... you dont use it with the carbon mount in the password kit
Old Jul 14, 2008 | 08:00 PM
alscrx's Avatar
Default Re: (EFstyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle &raquo;</TD></TR><TR><TD CLASS="quote">the metal sleeve is ment for if you put the battery anywhere inside the car... you dont use it with the carbon mount in the password kit</TD></TR></TABLE>
Wrong....its to protect the battery from heat! You should use that if your putting the battery under the hood. You do not need it if installing inside the car!
Old Jul 15, 2008 | 02:28 PM
jfizzzle187's Avatar
Default Re: (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong....its to protect the battery from heat! You should use that if your putting the battery under the hood. You do not need it if installing inside the car!</TD></TR></TABLE>
BUT, he cant use the metal jacket if he is using the passwordjdm relocation kit because it wont fit. ditch the metal piece man.
Old Jul 15, 2008 | 02:43 PM
EFstyle's Avatar
Default Re: (jfizzzle187)
ive had my drycell from password for over a year and absolutly no problems at all... and if it was THAT important... dont you think ALL batterys would have a metal sleeve? ditch it...
Old Jul 15, 2008 | 04:16 PM
CharleyCRX's Avatar
i know i can use a small dremel and fix easy!!!!
exept i have the conviction of, when you pay for a kit (battery and relocator)
from the same place he suppose to fit perfectly!!!
i paid 150$ cdn for the relocator
and 210 for the battery
from password jdm ( i pass by a reseller in quebec)
i know now!
password is REALLY crap!
Old Jul 15, 2008 | 07:25 PM
Crx Jimmy's Avatar
Default Re: (CharleyCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CharleyCRX &raquo;</TD></TR><TR><TD CLASS="quote">i know i can use a small dremel and fix easy!!!!
i know now!
wow $210 for that battery I bought the same pc680mj from a battery wholesaler in florida and got it shipped for $80 AND it included the automotive screw in top terminals
Old Jul 15, 2008 | 07:38 PM
le diable's Avatar
i just came into the same problem a few days ago,
i took the metal jacket off the battery.
and for all who say it's for blocking the heat, the carbon fiber cover is doing the exact same thing.
works great for me
Old Jul 15, 2008 | 08:08 PM
EFstyle's Avatar
Default Re: (le diable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by le diable &raquo;</TD></TR><TR><TD CLASS="quote">i just came into the same problem a few days ago,
works great for me </TD></TR></TABLE>
you also have to take into consideration the location in wich the battery sits... how hot can it posibly get right next to the trans?
Old Jul 16, 2008 | 04:00 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by odyssey batteries &raquo;</TD></TR><TR><TD CLASS="quote">
Metal jacketed vs. Non-metal jacketed: The metal jacket is needed if it's being mounted near heat to protect the plastic of the battery from swelling. The lead plates are under much higher pressure than a lead acid battery and if the plastic heats up, the plates will want to expand outward which can ruin the battery if it doesn't have a jacket.</TD></TR></TABLE>
just wanted to add Odyssey's explanation of the metal jacket.
Old Jul 16, 2008 | 04:49 AM
Creator's Avatar
It doesn't even look like password jdm sells that part anymore. I guess thats kind of in there defense; but they're still over priced.
Old Jul 16, 2008 | 05:14 AM
G0crxG0's Avatar
OR this guy coulda put his battery in the trunk. much better idea IMO, unless you like extra wires and junk in your bay
Old Jul 16, 2008 | 07:33 AM
le diable's Avatar
okay i just got off the phone with the battery company,
they knew the kit and said the carbon fiber was doing the samething as the metal jacket.
also there is alot of air coming in the front of the car.
the only really way to get the kit to fit is without the metal jacket
to answer the original question
