another rear camber question
Old Jul 7, 2008 | 11:43 AM
bimmeris's Avatar
Default another rear camber question
just heard some confusing things on rear camber... ok there's the washer trick to correct negative camber at rear wheels right??? I've just been told that the washer trick doesn't correct neg camber at all on lowered car... and it make sense... when you drop, let say, by 2.25inch... the top of the rear wheels tends to point outside the wheel wells, cause the UCA move upward, changing the angle of the UCA and making it longer than at stock height... so to correct this you'll have to heat/cut/weld the UCA...
BTW i just bought a rear ajustable camber kit... but i still wanna know who's right??
Old Jul 7, 2008 | 11:50 AM
instructor74's Avatar
Default Re: another rear camber question (bimmeris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeris &raquo;</TD></TR><TR><TD CLASS="quote">just heard some confusing things on rear camber... ok there's the washer trick to correct negative camber at rear wheels right??? I've just been told that the washer trick doesn't correct neg camber at all on lowered car... and it make sense... when you drop, let say, by 2.25inch... the top of the rear wheels tends to point outside the wheel wells, cause the UCA move upward, changing the angle of the UCA and making it longer than at stock height... so to correct this you'll have to heat/cut/weld the UCA...
BTW i just bought a rear ajustable camber kit... but i still wanna know who's right?? </TD></TR></TABLE>
incorrect the wheel moves in when the ride hight goes down that is why the washer trick will work because it moves the upper control arm out pushing the top of the wheel outward correcting for the camber for the lower ride hight
Modified by instructor74 at 12:58 PM 7/7/2008
Old Jul 7, 2008 | 12:09 PM
justinCO's Avatar
Default Re: another rear camber question (instructor74)
If you have adjustable camber kit, just get an alignment. Or try to do it yourself by adjusting the uca outward (make it longer). There is no cutting/welding or anything, what instructor said was right. Have you never jacked your car up before? It's pretty obvious which way the camber goes when the suspension raises/lowers.
Justin
Old Jul 14, 2008 | 10:28 PM
Sic_DA_Nine's Avatar
can this trick create negative camber?
i have a set of 13 offset wheels and wanna put them on with my current ride height...
i wanna create negative camber to fit them while being slammed...
can the washer trick do that?
taquatch.
Suspension & Brakes
Feb 4, 2009 11:39 AM
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
9crx1
Jun 16, 2004 11:10 AM
Andrew 825SM
Aug 15, 2003 03:16 AM
Understeer
Apr 4, 2003 06:25 PM
