Lighting HID/Xenon kits, Retrofits and Associated Topics
Acura Integra ONE Headlight not working ... Xentec HID's
Old Jul 7, 2008 | 09:30 AM
InTeNsE805vp's Avatar
Default Acura Integra ONE Headlight not working ... Xentec HID's
Hi everyone, never posted here but here goes ....
So I was driving around the other day and noticed one of my headlights wasn't working. Got home and swapped out my ballast outta my other Integra, nothing. Swapped out the bulb from my other car, nothing. Put the OEM halogen bulb back in the car ... nothing.
It's only one side (drivers side) that is not working ... any ideas? suggestions? Buddy told me that the wiring for that side may have gone bad?
Thanks for your help!
Old Jul 7, 2008 | 07:17 PM
Default Re: Acura Integra ONE Headlight not working ... Xentec HID's (InTeNsE805vp)
Old Jul 8, 2008 | 06:39 AM
retrosolutions's Avatar
check your fuses, those ballasts suck up 15-17 Amps on start up because like other cheap kits they are very inefficient ballast designs. So there is a good chance it blew a fuse.
Old Jul 8, 2008 | 07:52 AM
Default Re: (retrosolutions)
ok thanks, will do ... it just didn't make sense to me that only one headlight wasn't working but again, I will check the fuses just incase, thanks
Old Jul 8, 2008 | 01:14 PM
bakertime's Avatar
Default Re: (InTeNsE805vp)
Yeah...you shouldn't been running aftermarket HID kits off of stock wiring. You can blow fuses or fry your wiring due to the amount of heat.
First step is get a relay harness, and then you can trouble shoot the other problem with two working headlights already!
Old Jul 8, 2008 | 02:02 PM
Default Re: (bakertime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bakertime &raquo;</TD></TR><TR><TD CLASS="quote">Yeah...you shouldn't been running aftermarket HID kits off of stock wiring. You can blow fuses or fry your wiring due to the amount of heat.
First step is get a relay harness, and then you can trouble shoot the other problem with two working headlights already!</TD></TR></TABLE>
Is this what I should get?
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jul 8, 2008 | 05:28 PM
Yes, but you want one with a sealed relay. PM me, I can help you with that.
Old Jul 8, 2008 | 06:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by retrosolutions &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but you want one with a sealed relay. PM me, I can help you with that.</TD></TR></TABLE>
will do, thanks
Old Jul 10, 2008 | 10:03 PM
bad ballast, blew a couple fuses but works fine with stock bulb ... will get the relays when I get my replacement ballast, thanks all
JDM-DC2K
Lighting
Nov 10, 2015 03:00 PM
EdWord
Dec 21, 2010 02:10 PM
RSX_TypE-1
17
Jun 21, 2006 07:23 PM
dFreezy
Feb 3, 2003 12:57 PM
