Soft Brake Pedal after CC-X Install
After installing the Endless CC-X pads there is a noticeable difference from the stock pads as far as brake pedal feel (not to mention stopping power!). The pedal now seems softer and requires much more pressure to get that first bite. After getting some heat into them the pedal seems to feel better and they bite much better...
My question: is the softer pedal feeling and lack of the results of the pad not being up to heat properly or is there something else going on? (like needing to bleed the fluid, rotors maybe...)
new rotors?
bed the pads in correctly?
My peddle has been soft since the day I installed the spoon calipers 10k miles ago. Does not realy mater, the car stops on a dime and I can moderate the pedal no problem. Add yes I've bleed the brakes, I've done it like 4 times since.
it may just be the pad makeup... better preformance/bite when warm than when cold.
there is no perfect pad.
OE = firm pedal with fair bite.... (cold)
Panther XP's = better bite but loads of dust and about the same firmness (cold)
(HOT)
OE = soft like butter, cracking like a craker
XP's = bite like a shark, less dust than cold, and are as frim as a rock
Will
-who is on his 6 (need 7th) set of front pads (36,000 miles)
(HOT)
Will
how did you break them in?
if you're reusing the old rotors, then you might still have stock pad material on those rotors. *if* this is the case, then break in will probably take longer. *shrugs*
you will definitely need to bed them in
also, with the endless pads, they are much more progressive and linear in their braking power, unlike other pads like Hawks which give instant bite but don't improve much after that
1. Perform (4) repeated light to medium stops, from 65 to 10 mph, to bring the rotors to temperature.
2. Perform (2) heavy stops, back to back, at a point just pending wheel lock, from 65 mph to about 5 mph.
3. Drive for (5) to (10) minutes to create cooling airflow, without using the brakes if at all possible.
4. Perform (3) light stops in succession.
5. Perform (8) heavy stops, back to back, at a point just pending wheel lock, from 65 mph to about 5 mph.
6. Drive for (10) minutes to create cooling airflow, without using the brakes if at all possible.
Don't get me wrong, from what I can tell I will LOVE these pads, jsut need to get to know them and know what to expect.
If you did all that, you should be able to smell the brakes and you should be able to feel them fading. (Right?)
You MIGHT want to repeat the entire procedure a second time, just to complete any remaining outgassing. After that, you should be good to go.
Like somebody said these pads are much more progressive than the stock pads (which were like a on-off switch at times) and they allow me a much wider range of feel and stopping power...
elcid
Jul 25, 2008 11:04 AM
__oversea
Feb 18, 2007 08:04 PM
