Random parts I have lying around. 1992-00 Civic engine parts.
For the D16Y8
1 low mileage shortblock (all internals, pulley, oil pan and sensors) $200
1 bare head, no camshaft, valve train, valve cover, but has valves installed. $40
One bare Intake manifold. $30 EDIT: Sold local
One stock manual throttle body with MAP and TPS sensors. $50
One power steering pump, without a pulley. $10
One VTEC solenoid with oil pressure sensor $25
One IACV valve $20
For the D16Z6
One VTEC head (no valve cover or VTEC solenoid) $100
One VTEC solenoid $25
One JDM (actually a D15B) fuel rail with OEM pressure regulater $20
One set of used OEM fuel injectors (~150K miles) $20
P28 ECU (for automatic transmission cars, but I can modify to work on manual if you want) $80
For the D15B7
One valve cover gasket. This is just the valve cover gasket, not including the spark plug seals. $5
One exhaust manifold and downpipe. $10
Misc:
One used STOCK 5 speed shift lever and shift ****. $5
One older Pioneer CD deck with removable faceplate, remote and wiring to fit
Honda and Acuras. Make an offer
One used proclutch stage 3, 6 puck, pressure plate, clutch, (what I believe to be a)
stock flywheel and trowout bearing if you want it. It has a few thousand miles on
it, and it came off a D15B I bought from a guy. I want a more OEM like clutch, so
I'm selling the 6 puck. Make an offer.
One Honda P2E ecu. If I'm not mistaken, it's the non-VTEC 1996-00 ECU? It's unmolested, so $50.
Most prices are best (reasonable) offer. None of the prices include shipping, but I'll use USPS if possible. I can put stuff up on eBay if you would like. Otherwise, I'm located in the Quad City Illinois/Iowa area if you would like to pick it up. The Y8 engine block I WILL NOT ship unless you arrange for it. If you have any questions, or requests for photos, send me a message or PM. You can email me at timbabeu2005@yahoo.com
Thank you.
One IACV valve $20
For the D16Z6
For the D15B7
Misc:
Thank you.
chochi vtec
Jun 2, 2011 10:03 PM
