CRX: '90 -> '88 Door Swap
'88 CRX. Dude's wife backed into my car while I was working on his VR-4. I'm not too concerned, its my beater, but I would like to get it fixed. There's a couple '90-'91 doors for sale locally real cheap.
Difference-wise, from what I understand; door-mounted seat belts, the side molding is somewhat different, as is the vertical plastic next to the glass. That's all fine with me. My questions are:
-Will the door itself bolt up to my chassis or are the mounts different?
-Will the '88's door panel bolt up to the '91's door?
-Can I swap the molding as well so that it is all uniform?
-What about wiring harness, does it still connect the same or will I have to swap over my '88's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hym3n »</TD></TR><TR><TD CLASS="quote">'88 CRX. Dude's wife backed into my car while I was working on his VR-4. I'm not too concerned, its my beater, but I would like to get it fixed. There's a couple '90-'91 doors for sale locally real cheap.
-What about wiring harness, does it still connect the same or will I have to swap over my '88's?</TD></TR></TABLE>
There is alittle more then that different...
If I am not mistaken the actual frame is different...here read this..it might help!
https://honda-tech.com/zerothread/2331577
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctang »</TD></TR><TR><TD CLASS="quote">not to take over the thread or anything but i was wondering if the inside door panel would fit a '90 crx si?</TD></TR></TABLE>
All of your door panels are interchangable.
I don't know why anyone would want to put 90 door panels on an 88 door, but it would have a hole at the top close to the top where the glass meets. The 90 up USDM door glass is shorter. Look at the difference between the door pillar on the 88 thinner, vs the 90 which is thicker.
Yes but u will have to cut out a little section of the 90 door. Its about 4"-5" tall and 2"-3" wide. It is right above where the door locks to the car chassis.
No
Yes
Yes u will have to swap out the harness because the 90 door will have bigger connector because it includes some wires from the seatbelt mechanism. The 88 door harness only includes speaker wire.
You will also need the 90 seatbelt buckles because the 90 seatbelt will not fit into an 88-89 buckle.
I did this swap a while back so let me know if you need anymore information.
No
Yes
streetlegal gocart
10
Dec 2, 2004 11:50 AM
