something wrong with my engine?
Old Jul 6, 2008 | 06:00 PM
tekniq's Avatar
Default something wrong with my engine?
is it normal to run at 4k rpm when i'm going 75 m/h? seems kind of high to me and has been eating my gas. I have an em1 ('00 civic SI). thanks!
Old Jul 6, 2008 | 07:07 PM
tekniq's Avatar
Default Re: something wrong with my engine? (tekniq)
bump.
Old Jul 6, 2008 | 07:11 PM
TOO MUCH TORQUE's Avatar
sure civic si require short gears(high rpms) due to its torqueless engine. gas mileage is more dependent on throttle position, not rpms on hondas.
Old Jul 6, 2008 | 07:12 PM
Frozen E's Avatar
H-T White Ops
It's normal.
And how did you think something could be wrong with your engine if the RPMs didn't seem right? I mean, the link between the engine and transmission is mechanical. It's either moving or it's not.
Old Jul 6, 2008 | 07:19 PM
tekniq's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">It's normal.
And how did you think something could be wrong with your engine if the RPMs didn't seem right? I mean, the link between the engine and transmission is mechanical. It's either moving or it's not.</TD></TR></TABLE>
could you elaborate. thanks.
Old Jul 6, 2008 | 09:06 PM
Frozen E's Avatar
H-T White Ops
Default Re: (tekniq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">
could you elaborate. thanks.</TD></TR></TABLE>
Ok, you're the second person that's asked me to friggen elaborate on something today.
It's not really hard to understand. The engine is "attached" to the tranny via the clutch. The speed of the engine depends on the the RPMs that the tranny is spinning at. THAT speed depends on the actual mechanical gears INSIDE the tranny. It's called GEARING. Nothing you can change in the ECU or on the engine is going to change that. So unless you changed out the gears the RPMs are going to be what they are.
That's it, I'm done elaborating for the day.
Old Jul 6, 2008 | 09:18 PM
rSol93's Avatar
Yep yep, Si tranny=shorter gears= higher revs for lower speeds
Old Jul 6, 2008 | 10:58 PM
pkdog167's Avatar
Default Re: (rSol93)
My integra GSR go 4krmp @ 70mph something really wrong with it
Old Jul 6, 2008 | 11:18 PM
tekniq's Avatar
you must be having a bad day...but thanks for the info
Old Jul 7, 2008 | 05:01 AM
SOHC_4dr's Avatar
there is nothing wrong with any of your trannies
Marshal kokogyi
Apr 4, 2017 07:31 PM
jr408
Mar 5, 2008 03:12 PM
msinsky14
Jun 8, 2006 05:50 PM
Papichulo1767
Aug 2, 2004 06:30 AM
