Converting 1998 Civic ex to 2000 Civic Si
Old Jul 6, 2008 | 05:47 PM
reyrey2006's Avatar
Default Converting 1998 Civic ex with rear drums to 2000 Civic Si rear disk
What do I need for a rear disk brake conversion? I posted this under Acura Integra by accident!
Modified by reyrey2006 at 1:03 AM 7/7/2008
Old Jul 6, 2008 | 05:55 PM
BlueIntegraBoy's Avatar
Default Re: Converting 1998 Civic ex to 2000 Civic Si (reyrey2006)
Rear trailing arm assembly, ebrake cables, prop valve.
Old Jul 6, 2008 | 06:07 PM
tonylor89's Avatar
if ur car is equipped with abs then u don't need to do a swap......but if u r running with back drums then u need the whole back arms n rotors n brake lines n the whole assembly
Old Jul 6, 2008 | 06:09 PM
count me out's Avatar
* B A N N E D *
Default Re: Converting 1998 Civic ex to 2000 Civic Si (tonylor89)
lol. si brakes are worse than an ex with drums.
Old Jul 6, 2008 | 06:18 PM
.illwhitecoupe.'s Avatar
Default Re: Converting 1998 Civic ex to 2000 Civic Si (count me out)
I don't doubt your post, but can you elaborate?
Old Jul 6, 2008 | 06:53 PM
riceburnerryan's Avatar
to the OP... you posted the same thing in this forum like 3 times...
but to count me out... how are Si rear discs worse than an EX with drums?
Old Jul 6, 2008 | 07:03 PM
* B A N N E D *
Default Re: (riceburnerryan)
well for one, the weight. for two the prop valve. ever notice how your rear pads wear out after youve replaced the fronts about 7 times? ive owned both an ej8 with drums AND an em1 and my ej8 brakes just felt better.
spend some time in the road racing forum. a lot of the setups are just real good rotors/pads up front and drums in the rear.
you can always do the rear disc conversion for the bling factor.
Old Jul 6, 2008 | 07:04 PM
hmm.. never had that problem on my last car.. they would wear evenly...
Old Jul 6, 2008 | 07:05 PM
* B A N N E D *
what was your last car? if your front and rear pads on a civic wear evenly there is something wrong.
Old Jul 6, 2008 | 09:51 PM
1994 civic coupe... with i believe the EG Si rear discs... but yeah if anything... i changed my fronts maybe once more than the back...
Old Jul 6, 2008 | 11:14 PM
Historyg's Avatar
i have the rear si brakes, with the right prop valve i replaced my front two times before replacing my rear, I have no idea what uneven wear you are talking about.
Old Jul 7, 2008 | 08:00 AM
* B A N N E D *
i exagerated a little bit on the 7 times but, rear discs really dont do dick.
Old Jul 9, 2008 | 08:46 PM
reyrey2006's Avatar
Default Re: Converting 1998 Civic ex with rear drums to 2000 Civic Si rear disk (reyrey2006)
Ok, thanks for everyones help on this I appreciate it, I know that the Si rear disk assembly wil work but will the rear brake assembly from an Integra work?
I also wanted to know if the I can just change out the front calipers from my Civic to front calipers from Integra without any major mods?
Old Jul 9, 2008 | 11:18 PM
Historyg's Avatar
you need to change the master cylinder if you want to change the front, for the rear you can keep you cylinder.
STCYRIOUS
Sep 20, 2015 06:28 PM
wh1tel1ght
Mar 18, 2010 06:34 PM
phatmonsters
Jan 27, 2007 12:14 AM
1nicegsr
Honda Civic (2001 - 2005)
Jan 15, 2007 03:52 PM
JICB16B
Feb 27, 2003 06:38 PM
