What axle fits gsr tranny with quiafe
installed a new flywheel on my b16 swapped eg with gsr tranny and quaife lsd, discovered that both axles were in need of replacing. Drivers side was no problem using a b16 axle but the passenger side didnt fit up correctly, took the axle out of a non lsd b16 tranny that had no problems but it wont seal properly, When placed side by side my busted axles splines were shorter going into the tranny than the normal b16 so it would leak out transmission fluid. The car came with the swap so my question is what axle should i buy for it since i cant seem to find anyone localy to rebuild it
you hould be able to use any 94 or newer integra axle they are all the same just make sure you get the rite side one time i bought one and they gave ne the wrong side actually took me a while to figure it out but all hydro b series axles are the same
i talked to my friend who supplied the axle that didnt fit and it was infact a 95 gsr axle, he was stumped as why it didnt work, only thing he could think of was maybe to use a del sol b16 axle, any ideas
