Rear sway bar
I think suspenion techniques does..like $239.95 through http://www.jcwsportcompact.com
I know of two that make it for the CRX....Neuspeed and Suspension Techniques.
Neuspeed is kinda pricey for 419...but I found an ST set for 268 here http://www.driverfx.com/products/pro...=1027097709468
i used to run a ITR bar on my EF
to make it work you will need:
bar complete with endlinks/bushings
drill two holes on each side (crossmember)
add some reinforcment plates
LCAs that can accept the bar
Another source is ADDCO. They actually have a website and are one of the original makers of bars for imports. Factory is in North Carolina. They sell both direct and thru Summit. I have a #456 on the rear of my 89CRX
DON'T do the ITR bar...
it's a waste.
Get the ST set from Summitracing for like $240+ shipping and sell the front bar to some idiot ricer or trade it with a friend who has a Si front bar and install the front Si one and the rear ST one.
it's a waste.
http://www.lithningmotorsports.com will sell just the rear st bar for less than $150.
there was a sway bar on the rear disc set up I bought from a 90-93 teg. It's the full suspension. could I use it?
[Modified by wronghand, 5:53 PM 7/19/2002]
Here you go...
http://www.street-beat.com/honcivall88r.html
They sell just Rears or just Fronts. I ordered mine from them.
ALL from Nopi
ST front and rear kit $ 233.75
ST front $126.23
ST rear $126.23
Nesspeed front $174.33
Neuspeed rear $348.71
Eibach front and rear $325.05
ST front $126.23
ST rear $126.23
I used to have some minor clearance issues with my 2.25" exhaust and my 22mm rear sway bar (ST) but they were fixed when I went with the sidepipe. I don't have a rear tie bar and I don't believe you'll want one after you put in the sway bar... can you say "FWD drift?".
R91Si
Oct 12, 2002 08:36 AM
. That thing has been sitting around on a pallet for 3 months. The beach takes my free time every weekend, so nothing gets done to the car.
