b20 bottom end specs
Old Jul 5, 2008 | 08:13 PM
GSR_hatch936's Avatar
Default b20 bottom end specs
Ok im going to rebuild a b20 bottom end and just need to know all the internals specs and if anyone gots these that would help alot.
Thanks.
Old Jul 5, 2008 | 08:15 PM
EkFG's Avatar
Default Re: b20 bottom end specs (GSR_hatch936)
what kind of spec's
Old Jul 5, 2008 | 08:22 PM
Default Re: b20 bottom end specs (EkFG)
I found some. Correct me if they are wrong.
Oil pan to block nuts/bolts - 8.7 ft/lbs
Oil drain plug - 33 ft/lbs
Oil pickup tube to block/oil pump - 8 ft/lbs
Windage tray bolts - 8 ft/lbs
Flywheel to block bolts - 76 ft/lbs
Pressure plate to flywheel bolts - 19 ft/lbs
Main bearing caps - 56 ft/lbs
Rod bearing caps - 23 ft/lbs (Refer to ARP's instructions for ARP rod bolts)
Oil pump to block (12mm) - 17 ft/lbs
Oil pump to block (10mm) - 8 ft/lbs
Water pump to block bolts - 8.7 ft/lbs
Thermostat to block bolts - 8.7 ft/lbs
Old Jul 6, 2008 | 08:00 AM
bump for more info.
sanman000719
Apr 2, 2012 02:14 PM
Adi Radoncic
Dec 31, 2003 01:07 AM
UncleBen'sRacing
Feb 16, 2003 01:17 PM
