zc piston in a d15
Old Jul 5, 2008 | 07:23 PM
m2theizzy's Avatar
Default zc piston in a d15
can i stuff my d15 with zc pistons? am also planning 2 swap the d15 head with a 99 vtec head can that be done also?
Old Jul 6, 2008 | 07:44 PM
ponchdriver16's Avatar
Default Re: zc piston in a d15 (m2theizzy)
definatly possible. would put your compression ratio to 10.64:1. also the vtec head will bolt right on. do yourself a favor and get the updated headgasket and head bolts from honda. also go to http://www.zealautowerks.com/dseries.html to figure out different combinations that will suite your needs. good luck
Old Jul 8, 2008 | 10:51 AM
m2theizzy's Avatar
thankx cool site
Old Jul 8, 2008 | 01:26 PM
2slowGs-R's Avatar
headebolts you will need it specifically to the year of your head...found out why the studs were too long
Old Jul 11, 2008 | 02:03 AM
likwid2u's Avatar
if its stock dx bottom end then you need to change the rods if its d15b vtec then you dont need to swap the rods
cunnart
Jan 8, 2018 09:58 PM
spens 91 Ef
Sep 13, 2009 09:04 PM
macjr
Mar 13, 2004 09:47 PM
BenenEK
Dec 27, 2001 04:31 PM
