Your opinions on polyurethane bushings...
Old Jul 5, 2008 | 06:46 PM
PhatRoyale's Avatar
Default Your opinions on polyurethane bushings...
Do you think that they would be too stiff or unbearable for a daily driver?
I'm thinking of replacing my stock rubber bushings with polyurethane ones since they're starting to wear out. Please post your thoughts and opinions.
Old Jul 5, 2008 | 07:17 PM
ej civic noob's Avatar
Default Re: Your opinions on polyurethane bushings... (PhatRoyale)
imo the poly will be fine for daily driving, almost every car ive owned ive swapped over to poly bushings when ive done suspension work and ive always been happy with the results. of course comfort is very subjective, but to me ive had no issues
Old Jul 5, 2008 | 07:31 PM
EGbubble's Avatar
Will you be tracking your car at all?
It will be a little rough for daily driving but if you're racing your car then it might be a good trade off
Old Jul 5, 2008 | 09:31 PM
Devon M's Avatar
they'll be fine. I believe Type R's come factory with polyurethane bushings.
Old Jul 5, 2008 | 09:33 PM
ke98248's Avatar
Depends on the application and use of the bushings.. Poly urethane bushings in control arms -- no. But shifter bushings and motor mount inserts, yes.
Unless this is a track car or something. That's different.
Old Jul 5, 2008 | 09:48 PM
Kendall's Avatar
I think you may be pleased with the results. It is a wee bit harsher, but since the motor physically moves less, there is less latency between hitting the gas pedal and the car actually moving. It's nothing that won't work very well in a daily driver.
Honda Type R
14
Jul 13, 2015 07:34 PM
fastboy559
13
May 20, 2009 05:05 PM
Red Balut
Suspension & Brakes
16
Jan 25, 2008 01:17 PM
007EG
Suspension & Brakes
22
Jan 3, 2008 06:43 PM
Nothing.Special
Suspension & Brakes
May 23, 2005 09:47 AM
