5 lug swap on a 02 ep3 questions
My friend wants to put rsx 5 lug on his ep3 and was wondering if the spindles will bolt into stock front lca's or does he need the rsx one's also?
Modified by ITR.#1446 at 7:34 PM 7/5/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red 5 »</TD></TR><TR><TD CLASS="quote">RSX/EP3 lca's are the same. It will bolt right up.</TD></TR></TABLE>
This is only true for the 02-04 RSX. In 05+, the RSX-S used a larger taper ball joint, so if the knuckles come from an 05+ RSX-S, you will need to get the 05+ RSX-S LCA as well.
If your friend wants the base 5-lug then I believe 02-06 LCA should be fine, since they still use the smaller ball joint.
Correct (I've done this).
Wattup Though 00
May 28, 2004 05:37 AM
