wiring up your jdm doors
Old Jul 5, 2008 | 05:31 PM
thevtecnician's Avatar
Default wiring up your jdm doors
I searched and searched, and searched for instructions on how to wire up my jdm doors and found nothing but factory manuals. Welp, I'm not really a technician(despite the name lol) so I can't read that stuff!
Anyway, I figured it all out and here it is. ithis is how I wired up the jdm doors on my 88 crx and 91 hatchback. If I wanted to, I could've wired up the master switch on our passenger side to control both windows but I opted against that. However, the one touch control still works on the passenger side. Enjoy!
Power window wiring. If you use this diagram you use the switches that come on the jdm doors.
Wire color and function for the usdm driver side door at the door plug(jdm passenger side)
Blu/blk 12v+ switched source
Blu/yel ground
Fat blu/grn ground
Grey/blk speaker
Blu/grn speaker
I used this diagram below on my 91 civic hatch to use the harness that went to the door from the factory. It was aplug and play affair once I repinned the door plug.
(chassis harness)
Blk ground
Wht/grn 12v+ constant source(even without key)
Wiring for the Usdm passenger side at the door plug(jdm driver side)
Yel/wht 12v+ switched source
Black ground
Blu/blk ground
Red speaker
Brown speaker
These next 3 wires are used only if you want to have control of both windows with the master switch which is on the passenger side. You would run these wires from the passenger side to the driver side and splice into the same color wires at the switch.
Fat blu/grn goes to driver side
Blu/yel goes to driver side
Thin blu goes to driver side
AddictionJDM
Honda Civic (2001 - 2005)
Jun 9, 2016 05:16 PM
kammy11
Jul 1, 2013 09:23 AM
who-got-rice
Mar 7, 2010 06:04 PM
LwdJdmR
Jun 3, 2008 05:47 PM
BodyKits NW
Audio / Security / Video
Nov 5, 2006 09:00 AM
