Need Help, motor problem w/Z6
Old Jul 5, 2008 | 04:44 PM
jb0705's Avatar
Default Need Help, motor problem w/Z6
Wsup Everyone,
I'm in need of some help, I have a Z6 swap on my 91 Civic. The car sat in my garage for at least 6 months without being started. I just recently started and drove it. Now my problem is, that the car is now chocking crazy. When you suddenly accelerate the car it will choke. I tried putting in fuel injection cleaner and still did not work. Can someone please help me out..
Old Jul 5, 2008 | 04:55 PM
90crxdriver's Avatar
Default Re: Need Help, motor problem w/Z6 (jb0705)
The gas may have went bad sitting that long.
Old Jul 5, 2008 | 04:58 PM
jb0705's Avatar
Default Re: Need Help, motor problem w/Z6 (90crxdriver)
Sorry, forgot to mention that I did fill up with new gas. There was still half a tank left over from 6 months ago.
Old Jul 5, 2008 | 05:00 PM
Humm try doing a full tune up on it and see if that works.
My Mitsubishi sat for over a year and it ran really bad after I got it started with new gas after a full tune up it was back to normal.
Old Jul 5, 2008 | 05:43 PM
BlueCrxNC's Avatar
The car was running good before it was parked for 6 months right? This isn't a swap that's just now being run correct?
Old Jul 6, 2008 | 02:24 AM
jb0705's Avatar
Default Re: (BlueCrxNC)
The car was running good before, and it's with the swap already.
Old Jul 6, 2008 | 04:13 AM
BlueCrxNC's Avatar
I had my car sit for a complete year (1/4 tank, ~3 gallons ). At first, I just added good gas (5 gallon) on top of the old... ran like complete ****. Drained the entire fuel tank by the drain bolt in the rear driverside, then added a few gallons of good fuel. Changed plugs and was good to go. If you just added new gas on top of 1/2 a full tank old gas, all the water that built up over time and bad gas still remains in the mix refusing to burn well. Best to drain tank and tune up Sucks that gas only last a month or two once we get it. 3-4 month shelf life total including time in the gas station tanks IIRC.
Old Jul 6, 2008 | 07:05 AM
b20eg6hatch's Avatar
Change the fuel filter. If that doesn't work, pull your fuel pump and check the filter bag on it. Also If you have to pull the fuel pump then disconnect the fuel filter up front and blow air through the line from the tank to the filter, but make sure you put something over the end as you don't want to blow fuel all over your motor. GL
Old Jul 6, 2008 | 07:18 AM
beana's Avatar
drain your fuel tank ,put fresh fuel and when you put fresh fuel drop in some kind of injector cleaner
mczest0
May 26, 2009 01:28 AM
jb0705
Mar 24, 2008 07:42 PM
FLIPboi
Aug 29, 2002 07:16 PM
