Engine swap question?
Old Jul 5, 2008 | 04:01 PM
orion2's Avatar
Default Engine swap question?
I have a 93 Honda Civic hatch and I swapped the D15 that came in it for a B18 from a 94 Integra. I used the ecu and and the wireing harness from the D15 on the B18 and its running like crap. My question is can I use the D15 computer with the B18 or should I have used a B18 computer and wireing harness? What would you guys recommend?
Old Jul 5, 2008 | 05:33 PM
superfast666's Avatar
Default Re: Engine swap question? (mcvtec)
why would you ask if you could use that ecu from the d15 did a integra come stock with the same ecu i think not common sense goes a long way
Old Jul 5, 2008 | 06:26 PM
rSol93's Avatar
D series ECU for a B series, im not a computer genius but, I don't think your supposed to do that.
Old Jul 5, 2008 | 08:35 PM
JDM_Honda_349's Avatar
If it is a GSR then you want to run the GSR ecu cause a SOHC ecu doesnt have the secondary intake setup like the GSR ecu and you will notice a power loss from it. Run the B series ecu with the B series engine and do it right the first time so your not doing it a second time.
Old Jul 5, 2008 | 10:06 PM
Kendall's Avatar
What exact ECU is in the hatch right now? That would be the first thing to find out.
Old Jul 5, 2008 | 10:39 PM
simonizkool's Avatar
New User
Default Re: (Kendall)
whats the ecu right now
1HGEJ2
Engine Management and Tuning
Aug 22, 2017 04:08 PM
HAMOTORSPORTS
Performance
Feb 18, 2015 12:42 PM
Black_horse
K Series
Apr 22, 2013 02:56 PM
baulum
Jan 6, 2010 02:55 AM
