Quick headlight question
Old Jul 5, 2008 | 03:06 PM
iluvmy2000civicex's Avatar
Default Quick headlight question
I have a 2000 Civic Ex and I want OEM black housing headlights... no replicas. I've got alot of other things going on with the car and I dont want to spend the money that OEM CTR headlights require. I have searched and searched for the past few hours on this stuff. I have found a few good DIY's for painting my OEM headlights. What would you guys recommend? Is it as easy as the diy's make it look?
Should I do the diy black housing project on me OEM headlights or should I buy some that some one else has alredy put the time into or should I save up and buy some OEM CTR headlights?
Old Jul 13, 2008 | 08:16 PM
98_EX_sleeper's Avatar
Default Re: Quick headlight question (iluvmy2000civicex)
the DIY way is tricky don't believe all the pics its not as easy as it looks when you do it you have to be quick about it because when you bake your headlight in the oven to soften the glue that holds the housing and lens on you have a matter of minutes till it hardens then you run into the chance of burning a hole through the headlight itself if your not careful so honestly if you can find someone who has done it already and is selling the lights then go for it or buy like you said but best of luck with it man
Old Jul 13, 2008 | 08:18 PM
Default Re: Quick headlight question (98_EX_sleeper)
oops forgot to add... when you do it to spray paint it you have to bake it twice to soften the glue and split them apart and to soften the glue to mold the two back together
Old Jul 13, 2008 | 09:13 PM
NOFX's Avatar
H-T White Ops
The replicas are basically what you're meaning to make. There are replicas out there that have a similar color to the CTR lights, but generally speaking they're the same thing you'll be making at home.
I'd personally just stick with OEM lights and clean them up. I wouldn't try to paint them or anything. It's hard enough finding clean '96-'98 headlights. Oh, and if your lenses are already foggy, black paint will only make them look worse.
Old Jul 13, 2008 | 10:30 PM
mattyfo0z's Avatar
Default Re: (NOFX)
I agree with NOFX - I definitely would keep them OEM and just try to buff or polish them so they look like new if they're foggy or something. Of course there are some cars that could pull off black housing headlights or CTR headlights, but a good amount of the time they don't look too hot.
Just my opinion.
Old Jul 14, 2008 | 12:36 PM
Default Re: (.mattyz_)
deff. agree with NOFX & mattyz if there foggy and faded alittle just get some really fine grit sandpaper scuff the surface then put a good polish on them
Old Jul 14, 2008 | 12:48 PM
JDMguy88's Avatar
Default Re: (98_EX_sleeper)
Or autozone, and I'm sure all the other auto stores, sell a headlight restoration kit that has everything you need to restore foggy headlights and its not too expensive
Outrun
10
May 23, 2020 10:46 PM
Lightsped
Aug 11, 2011 10:36 AM
liquid_imagination
Honda Civic (2001 - 2005)
20
Oct 3, 2008 08:14 AM
kcari
49
Sep 5, 2007 02:24 AM
