Problem going from no power steering back to power steering
Question...
My dd had the padawan ps removal kit on it when I bought it about a year ago. I recently decided to put the ps back on replacing everything back to stock. The pump whined and I had sporadic ps, usually in the middle of a corner.
I took that pump off and put the one I know works from my race car on, now there is no whine but I still have no ps. Am I missing something? I have the shop manual but nothing seems out of place unless im missing something from the padawan kit I didn't notice.
Thanks for the help
Thanks for the help
Pretty much, when im in the middle of a long corner I can feel the ps begin to work but as soon as I straighten out the wheel or when im sitting still I get nothing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky »</TD></TR><TR><TD CLASS="quote">Is there enough fluid in the system?</TD></TR></TABLE>
Yea, and there are no leaks or anything
Two thoughts:
1. Maybe the rack needs to be bled? If that's at all a concern, I think just sitting still with the car on and turning the wheel back and forth a few times would do it. Recheck fluid level when you're done, and if it's lower you had air in the system.
2. Any chance the lines are backwards/crossed at either the pump or the rack? I kind of remember the fittings on the rack being different sizes, but I'm not 100% sure.
Tried the lock to lock method and got no results.
The lines are indeed different sizes at the rack as well, the bottom is a hard line and the top gets a hose.
Its gotta be something simple im missing as I know the pump works perfectly
rolledthatho
13
Feb 12, 2011 06:13 AM
md88hfcrx
Oct 27, 2006 05:13 PM
