99-00 honda si gauge cluster
ya its been done. you can also put in the teg clusters. all you gota do is search for the wire pinouts for the si cluster and your stock cluster then splice in the si coupe cluster plug and make the cluster fit in your dash. and your also gona have to get a electric vss and plug and wire it in to replace your cable one. when i did a 95 teg cluster almost all the wire colors were the same as a the stock crx wires.
Teg = Integra
and ive seen it done before, as black0hatch said, you gotta find out wire pinouts,
and try to fit the cluster in.
https://honda-tech.com/zerothread?id=1053318
hope that helps
its not accurate...but your going to have to use your noggin.
hope that helps
click the red search button then search cluster pinouts in the ef forums. its gona tell you what each wire does. then click the red search button again and search cluster pinouts for a ek. its gona tell you what each wire does. write them both down and match them up. its not as hard as your making it. once all the wires are matched up make sure everything works. next go get an electric vss and switch it with your cable one. run the wires to the cluster. ones ground the others 12v and the last one is signal for your speedo. last make any small modifications to get the cluster to sit in there and not move around. i didnt even need brackets for mine.
97_Ek
Mar 13, 2008 08:55 PM
MBlake55
Feb 4, 2008 08:18 PM
