Wiring up Dynasty 200 for 115V power
Old Jul 5, 2008 | 08:12 AM
dfoxengr's Avatar
Default Wiring up Dynasty 200 for 115V power
Just upgraded to the dynasty 200 from my sync 200. Im going to wire it for the 4-prong plug for 230V, but I also want an adapter for 115V. how would I go about doing that?
Ive seen adapters at walmart for RVs which looks like 230V 3-prong to 115V but i dont really know if thats what theyre for or if its just a special RV plug.
Old Jul 5, 2008 | 08:47 AM
89civicdx's Avatar
Default Re: Wiring up Dynasty 200 for 115V power (dfoxengr)
I wired mine for 115 on it always... then I made an extension cord with a 115 female to the 230 male. So you can play around with it like 230 always with a 230 recepitical to a 115male. All the stuff you can buy at home depot....just don't ask them for any advice lol.
edit
Mine actually goes to from 115 female to 3 prong dryer plug by the way.
Modified by 89civicdx at 9:53 AM 7/5/2008
Old Jul 5, 2008 | 02:25 PM
dfoxengr's Avatar
Default Re: Wiring up Dynasty 200 for 115V power (89civicdx)
so whatd you do with the green wire for 115?
Old Jul 5, 2008 | 06:32 PM
89civicdx's Avatar
Does this help?
http://www.millerwelds.com/res...iring
lol the first time I heard it I was nervous too!
There is a pic in this topic of one guys adapters
http://www.millerwelds.com/res...dryer
Old Jul 5, 2008 | 08:00 PM
dfoxengr's Avatar
ok got it and it works on the 115V plug
basic thing to remember is to tape back the red wire from the machine.
I used a 4-prong 50A male plug on the machine wiring. the green wire went to the u-shaped pin, the black to one of the side ones, and the white to the flat pin opposite the green.
then a female of the same with matching wires connected to a 3-foot 10/3 cable, and a regular 115V male plug on the other end.
thanks
Old Jul 6, 2008 | 03:14 PM
StillBoostin's Avatar
230v only uses 3 of the wires. So why are you using a 4 prong 230v plug. I made an adaptor for my dynasty too. If you need picss let me know.
James
Old Jul 6, 2008 | 04:29 PM
dfoxengr's Avatar
Default Re: Wiring up Dynasty 200 for 115V power (StillBoostin)
Please post pics of your setup.
I think I just figured out that I needed to put the white wire on the side opposite the black, instead of where I put it opposite the green on the bottom.
Im using the 4-wire plug because the new code for dryers is 4-prong.
My dryer is 4-prong, and the 220 that is in my parent's garage is 4-prong.
I am going to switch the white over to the side prong.
But then Im pretty sure I need to tie (jump) the green prong into the unused bottom one so that it will work when plugged into the 4-prong wall receptacle.
Can anyone confirm this?
Old Jul 7, 2008 | 05:52 AM
89civicdx's Avatar
My dryer is also 4 prong but I use this ....this thing came with the wires already attached(dryer replacement plug).
Modified by 89civicdx at 6:59 AM 7/7/2008
Old Jul 7, 2008 | 06:03 AM
dfoxengr's Avatar
gotcha, thats the same thing I have. So you didnt need to jump the green wire to the L-shaped bottom prong for any reason? I thought I had been told that would be necessary but I dont know.
im going to change my setup to a 4-prong twistlock on the end of the welder cable. this will keep the red wire incase I need to go 3 phase ever. then Ill have a few adapters from the 4-prong using the wht/grn/blk only to 115, 230 dryer, etc.
Old Jul 7, 2008 | 06:28 AM
89civicdx's Avatar
well I just opened it to make sure as it was a while ago I just see it wired up to the round(green) and the 2 | |
Old Jul 7, 2008 | 11:15 AM
dfoxengr's Avatar
ok cool, Ill get that done tonight.
-derek
Yuta
15
Jul 26, 2016 07:46 AM
Drama13
Dec 19, 2012 02:15 PM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
vi3tromanc3r
Feb 11, 2007 03:41 PM
sporty240
Apr 20, 2006 07:05 PM
