Jdm 16 inch dont fit ?
well i found a good deal on the jdm 16 inch itr wheels so i pick them up my car was running on stock size tires with the stock 15 inch r wheels and everything was fine well i go to swap them out and everything goes fine but the rear on both sides rubs on the chamber kit it has already shaved some metal off the inside of the wheel weight any ideas ? i figured you guys would no best
215/45's is what comes stock on JDM ITR's. Shouldn't have any problems with rubbing if you're running on stock suspension. if its lowered, you'll need to roll your fenders and get an aftermarket rear camber kit to keep the tire from rubbing on the rear upper arm since its smaller
you just need to change your wheels weights, mine did this same thing when i put the JDM 16's on my car,
you need the weights that stick to the inside of the wheels, not the ones that clip on to the inside lip if the wheels,
or a 5mm spacer, either way it's a quick fix,
Read carefully. His tires aren't rubbing. The rubbing is caused by wheel weights on his wheels. So the tire size doesn't matter; it's not the tires that are rubbing.
If that's the only place there's rubbing, use the other kind of wheel weight. If the rubbing is on bang-on wheel weights on the lip of the rim, then remove them and balance the wheels using stick-on wheel weights on the inside of the rim. And if the rubbing is from stick-on weights, switch to bang-on weights.
Like Sfedai0, I had a set of stock (15") wheels with stick-on weights mounted on the inside of the rim, and they interfered with the front calipers. So I switched to bang-on weights, no problems now.
EDIT: I typed this while Reyes was posting the same thing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 »</TD></TR><TR><TD CLASS="quote">The wheel weights on the inside will rub. I had the same problem. You can move the weights to the inner lip. </TD></TR></TABLE>
same problem happens to me too so i took off the weights on the inside and no more rubbing.
me too. just figured this out for myself last week
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legomytego »</TD></TR><TR><TD CLASS="quote">
Why is the bolt not fully tightened?
i just left it lose for the pictures because i was adjusting the camber kit
any insite on what kinda spacers i should get do they need to be hub centric ? and do i need to get just the basic flat spacer for 5mm or something like the h&R thats like a hub with studs ?
legomytego
Suspension & Brakes
Jul 5, 2008 04:49 PM
Tommy_Gunns
Sep 11, 2002 09:49 AM
