Need some suggestions!
Old Jul 5, 2008 | 01:11 AM
Sixfortyfive's Avatar
Default Need some suggestions!
since im getting my first honda soon and i've already found it. it has these mods in it and puts down 195whp. i was wondering if there was anything else i could upgrade/replace since im looking to get around 205+ whp. btw the block is stock. im really new to all this so HELPFUL SUGGESTIONS are welcome
Engine:
GSR rebuilt motor with papers
ported head
match ported skunk2 intake manifold( Carb sticker)
skunk2 stage 2 cams
skunk2 cam gears
310 rc injectors
tuned on chrome (195 whp)
supertech valvesprings and retainers
Hondata intake manifold gasket ( ported to match head and manifold also)
stock gsr block
itr oilpump
walbro 255 fuel pump
Mugen Headgasket
B16 LSD tranny (with papers)
JDM itr 4-1 header ( with heat shield)
avid racing motor mounts
competition clutch stage 2 ( newly replaced)
12 lbs steel flywheel
2.5 CUSTOM exhaust with QTP electric cutout ( sounds stock when closed)
AEM carb short ram intake
let the flamming begin
Old Jul 5, 2008 | 01:12 AM
Default Re: Need some suggestions! (Sixfortyfive)
up top
Old Jul 5, 2008 | 03:07 AM
Dark@Powers's Avatar
So you don't want to tear back into the block correct?
-A Tri-Y header in the place of the 4-1 ITR, which is already is a great header, can help.
-trying a different intake
-3 angle valve job
Or you can take it to a dynapack and call it a day w/ the higher reading.
Old Jul 5, 2008 | 08:53 AM
Default Re: Need some suggestions! (Dark@Powers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark@Powers &raquo;</TD></TR><TR><TD CLASS="quote">So you don't want to tear back into the block correct?
-3 angle valve job
Or you can take it to a dynapack and call it a day w/ the higher reading. </TD></TR></TABLE>
1.I've seen tri-Y headers replicas around the forum are those jsut as good?
2. what kind of intake should i try using?
3. whats a 3 angle valve job?
Old Jul 5, 2008 | 12:30 PM
help me out here!
Old Jul 5, 2008 | 08:34 PM
Old Jul 5, 2008 | 08:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixfortyfive &raquo;</TD></TR><TR><TD CLASS="quote">
3. whats a 3 angle valve job?</TD></TR></TABLE>
1. They net similar performance gains, but the quality and resale value is not as high as the originals such as Hytech.
2. A velocity stack on the end of your intake can help, definently do not look for much of a gain in the intake category tho, but it would help in squeezing out the extra 10.
3. http://www.team-integra.net/se...D=353
Old Jul 5, 2008 | 09:02 PM
Now I've got a question or two for YOU!
Are you running a cat?
Your running stage 2's on stock gs-r compression, asides from the headgasket? I would say your on the bottom of the threshold on running those cams since you have a port job, I would personally be using stage 1's. Why did you decide to run stage 2's?
Old Jul 6, 2008 | 12:05 PM
i wasnt sure and a friend of mine used them so i guess i threw em on which wasnt so smart.. i dunno much how cars but im willing to learn. so i have stock gs-r compression cause my block is stock right? and no im not running a cat
Old Jul 6, 2008 | 11:46 PM
up top
Old Jul 8, 2008 | 02:09 PM
up top
Old Jul 8, 2008 | 11:27 PM
help this sucka out
Old Jul 10, 2008 | 06:29 AM
somne help here ?
Old Jul 10, 2008 | 07:39 AM
ruffrhyder's Avatar
As already mentioned a better header, high flow cat, since your here in cali, larger throttle body, v-stack, and cam gear tuning. I don't know who ported the head but they should have done a 3 angle valve job already, but that depends on who did the work.
If you don't wanna rebuild the block, (bigger bore, higher CR pistons) you really don't have much more options to bump your HP, but you can always do suspension mods, which will help out a lot, remember, gaining HP is the only thing that makes a car quicker
eg6 type-R
Mar 4, 2012 07:03 PM
ksears
Apr 23, 2011 10:27 AM
Da9teggy92
32
Nov 22, 2008 12:47 PM
CleanSiR
19
Sep 4, 2008 03:24 PM
sleepycivix
Dec 18, 2002 08:30 PM
