electrical problem maybe key cylinder???? need help anyways
Old Jul 4, 2008 | 11:49 AM
racingcrx's Avatar
Default electrical problem maybe key cylinder???? need help anyways
when i turn the key to the second position the lights that are suppose to come on, but it doesn't. and i was wondering if this could be a key cylinder problem or what. but i have no idea. i bypassed that with a switch so the lights would come on. but the car shuts off like theres no power going to the engine. i need help so i can keep my crx running.
TIA
Old Jul 4, 2008 | 12:16 PM
black0hatch's Avatar
Default Re: electrical problem maybe key cylinder???? need help anyways (racingcrx)
theres nothing electrical about the key cylinder lock. your problem is probably the ignition switch witch is screwed to the back of the ignition lock. how did you by pass it?
Old Jul 4, 2008 | 01:07 PM
89civicdx's Avatar
The car should stay on if you hold the key
I've dealth with this 2 or 3 times but now I can't rember if its the key cylinder or the switch...unscrew the switch from the back of the cylinder and use a phillips or even your key to turn the switch...you will see what is wrong then.
Bishop1976
Oct 3, 2012 08:31 AM
boost fed ls
Jan 4, 2009 09:43 AM
da9blk1
May 14, 2008 10:10 PM
GoldCoin
Oct 24, 2007 12:09 AM
