What is the ideal size rim for an ITR?
Old Jul 19, 2002 | 06:16 AM
01PYITR's Avatar
Default What is the ideal size rim for an ITR?
I was thinking 15x7.5 front and rear, whats your thoughts and which wheel would you buy (from what Co.? )
Oh and pushing near the 200 whp area
DutchITR1689's Avatar
Default Re: What is the ideal size rim for an ITR? (01PYITR)
I would say 16x7 like '98 JDM....
Old Jul 19, 2002 | 06:26 AM
01PYITR's Avatar
Default Re: What is the ideal size rim for an ITR? (George Knighton)
For everyday rippin use, Com'on you should know me by now...
and hitting the track when possible.
edit: So spoon or rotas would be a fine choice for 16x7 or does anyone else have an idea?
[Modified by 01PYITR, 10:28 AM 7/19/2002]
Old Jul 19, 2002 | 06:37 AM
nsxtcjr's Avatar
New User
19" diameter, 10" wide. Chrome.
Bling! Bling!
Old Jul 19, 2002 | 06:40 AM
SoCal ITR's Avatar
Default Re: What is the ideal size rim for an ITR? (nsxtcjr)
I'd agree with George.
Old Jul 19, 2002 | 06:50 AM
TsunamiZC's Avatar
Default Re: What is the ideal size rim for an ITR? (SoCal ITR)
are 15 inch rota's for my ITR (5 lug ) the same width as the stock itr rims
Old Jul 19, 2002 | 07:26 AM
Todd00's Avatar
I said I don't want a title!
Stock R rims are 15x6, which is stupid. 6" is too small IMO. 15" is fine, but at least give us some width.
Flux's Avatar
Stock wheels are 6"...
Old Jul 19, 2002 | 07:29 AM
TsunamiZC's Avatar
Default Re: What is the ideal size rim for an ITR? (Flux)
kooo...so when i get some rotas at least i'll gain .5 in width...
Old Jul 19, 2002 | 07:30 AM
Chris93Si's Avatar
Hmmm Spoons/Regamasters don't require hubcentric rings? Neato.
Old Jul 19, 2002 | 07:32 AM
yoshi234's Avatar
I shoot brides
Default Re: What is the ideal size rim for an ITR? (Chris93Si)
17x7.5"
Old Jul 19, 2002 | 08:45 AM
98R-1144's Avatar
Default Re: What is the ideal size rim for an ITR? (yoshi234)
15x7 here
Old Jul 19, 2002 | 09:05 AM
Asahi's Avatar
I think 15x7 is more than enough for a 205/50 and I think the 225's are too big for our cars no matter the wheel.
save the weight in the .5". I don't see any advantge to a 16" over a 15" other than looks.
Old Jul 19, 2002 | 09:08 AM
Asahi's Avatar
Default Re: What is the ideal size rim for an ITR? (98R-1144)
Can someone list options for 15x7?
Kosie K-1's are $500 ish
Dave-ROR's Avatar
20x9 chromed out.
Old Jul 19, 2002 | 09:09 AM
Turtle's Avatar
Default Re: What is the ideal size rim for an ITR? (Asahi)
I think some big 'old 18in Dayton's would look nice on an ITR...
AssPenny's Avatar
Default Re: What is the ideal size rim for an ITR? (Dave-ROR)
Hell yeah.. bling bling
Old Jul 19, 2002 | 09:32 AM
Reid's Avatar
Global Moderator
What makes you say that?
Old Jul 19, 2002 | 09:44 AM
SoCal ITR's Avatar
A: I heard that Kosie is no longer producing the K1's
B: I also understand that there may be some advantage to running 225's on the front wheels at the track
[Modified by SoCal ITR, 10:44 AM 7/19/2002]
Asahi's Avatar
Default Re: What is the ideal size rim for an ITR? (Reid)
The need for spacers in the rear and the rubbing that occurs. My car is lowered so it is out of the question for sure but even on Stock height ITR's spacers in the rear are needed to keep the tire off the trailing arm. I have seent his from several R's at national Tour Solo 2 events with 5 mm spacers. If I ran 225's on the front of my car they would hit the fenders.
Old Jul 19, 2002 | 09:45 AM
typer694's Avatar
New User
Dubs+2!!
Old Jul 19, 2002 | 09:47 AM
Asahi's Avatar
There was a big debate a long time about about the balance of the car mix matching 225's and 205's. Yoshi started the debate I think. Not sure what the consensus was but if I recall coreectly they decided this was common in japan but not good for car control.
I see lots of stock class ITR's at big Solo 2's doing this. some like it others haven't decided when I ask. I have never tried it.
Old Jul 19, 2002 | 11:25 AM
hooptie157's Avatar
pushin near the 200 whp area, WTF did you do to your car rob??
Old Jul 19, 2002 | 11:29 AM
Reid's Avatar
Global Moderator
You can always eliminate the rubbing.
You keep mentioning 225s in the rear, what's wrong with them in the front?
You can always raise the car up, if you ever decide you want the car to handle better.
Old Jul 19, 2002 | 12:34 PM
Zeus's Avatar
Ditto...
