steering feel improvement
Old Jul 19, 2002 | 05:19 AM
greensleeper's Avatar
Default steering feel improvement
any idea on how to improve the feel of an Accord's steering inout and feedback. the input sensitivity on my 5th gen sucks!! Don't know whether its 150K on the car or whether it sucks by design. My friends' civics and preludes don't feel nearly as crappy. Please insert opinions below.
Old Jul 19, 2002 | 05:24 AM
Gennady's Avatar
New User
Default Re: steering feel improvement (greensleeper)
Make sure your ps fluid reservuior is full, and your using Honda fluid.
Old Jul 19, 2002 | 05:26 AM
Default Re: steering feel improvement (Wont be beat)
what about the bearings? I know prothane and energy suspensions makes polyuerethane replacements for the civics. if I found one for the accord do you think it would help?
Old Jul 19, 2002 | 05:35 AM
YeuEmMaiMai's Avatar
since the accord does not have a subframe per sae, there are only so many things you can do
get a better rack
if you are on 14" rims change to 15" or 16" to eliminate tire flex
changing your suspension bushings will not really give you what you are looking for but it will make the car handle better
replace the engine tranny mounts or add some poly inserts
Old Jul 19, 2002 | 05:37 AM
personally I think that the accord has awesome steering.... weight of the car has a lot to do with steering feel.....civics are lighter and therefore easie to move around when you change steering input
Old Jul 19, 2002 | 08:40 AM
Default Re: steering feel improvement (YeuEmMaiMai)
this is true...
also when I was talking about poly bushings I referring specifically to the steering bushing.
Old Jul 19, 2002 | 10:56 PM
TypeSH's Avatar
You can get a smaller steering wheel. I think getting a larger power steering pulley might help, but not quite sure hwo the PS system works to really see if that would tighten up the feel. I also think wider tires would imcrease the steering resistance, so it might feel a lil better.
backbenchboy
Dec 16, 2011 04:12 PM
GunSamir
Jan 6, 2011 08:47 AM
hondazzza
Jan 6, 2011 08:32 AM
Andy T
Nov 9, 2009 07:01 PM
