9 SEC CRX NEW TURBO/MANIFOLD/CAMS
Old Jul 4, 2008 | 03:08 AM
CRX11Z's Avatar
Default 9 SEC CRX NEW TURBO/MANIFOLD/CAMS
hey guys, after running a best of 9.93@147mph in my b16a powered crx, i have now upgraded the turbo charger from the previous t3/60-1 (0.63a/r) to a GT35R- fitted with a 66mm T04R comp wheel and a 0.82 turbine a/r.
i have fabricated a much better turbo manifold and replaced the tial 38mm gate to a tial 44mm.
the standard b16a cams have been replaced with CTR cams and i have had the head slightly ported.
the bottom end consists of eagle rods,srp pistons and arp head studs, this engine has done well over 100 passes with 30psi+/9000+rpm and is starting to get a little tired!.... lol
im going to push is till funds permit a rebuild!
i am hoping with these upgrades the car will run 9.70@150+mph,if we run a 9.70 and the engine is still alive i will try some wheelie bars and shut the wastegate,see what happens.... just hope i dont end up in the wall!
check the link to some pix
And here are som pix of the old hi-mount exhaust manifold i made with the old t3/60-1
AND MY TOW CAR A 242GT VOLVO THAT I HAVE CONVERTED TO A HOLDEN 5.0L V8 ENGINE! GO THE VOLVOOOOO........ LOL
Modified by CRX11Z at 4:18 AM 7/4/2008
Modified by CRX11Z at 4:20 AM 7/4/2008
Modified by CRX11Z at 4:25 AM 7/4/2008
Old Jul 4, 2008 | 03:56 AM
DaveF's Avatar
Default Re: 9 SEC CRX NEW TURBO/MANIFOLD/CAMS (CRX11Z)
what is that sensor on the valve cover ? ref/sync ?
i also notice some bracketry off the oil pump ? for a ref sensor/trigger wheel ?
im going to have to assume you run a motec on the car(sticker on wing) ?
looks like that intake manifold fits much nicer on a rhd
very nice setup !
Old Jul 4, 2008 | 04:04 AM
CRX11Z's Avatar
Default Re: 9 SEC CRX NEW TURBO/MANIFOLD/CAMS (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">what is that sensor on the valve cover ? ref/sync ?
very nice setup ! </TD></TR></TABLE>
Yes i run a Motec M400 ecu, the sensor in the valve cover is a GT101 and is used for the sync position, the bracket on the oil pump is for another GT101 sensor- i run a 12 tooth choopper wheel of the balancer and is used for the ref.
Old Jul 4, 2008 | 04:15 AM
DaveF's Avatar
very nice !
do you have any shots of your motec box/ mounting panel ?
Old Jul 4, 2008 | 05:16 AM
Turbocivic94's Avatar
looks good
Old Jul 4, 2008 | 05:43 AM
Shadowz7429's Avatar
Damn, motec!
Old Jul 4, 2008 | 06:55 AM
DRIVENRacing's Avatar
nice!
Old Jul 4, 2008 | 07:44 AM
mec. pedri's Avatar
60-1 9.9 not bad
Old Jul 4, 2008 | 03:57 PM
speeddave's Avatar
Default Re: (mec. pedri)
impressive! how much does the car weigh? stock sleeves?
Old Jul 5, 2008 | 02:24 AM
CRX11Z's Avatar
Default Re: (speeddave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">impressive! how much does the car weigh? stock sleeves?</TD></TR></TABLE>
when i ran the 9.93 it was 1900lbs and yes its on stock sleeves.. i am very suprised this engine has run a heep of low 10s high 9s and still lives-
stock sleeves, eagle rods,srp pistons,stock oil pump,stock valves,and stock balancer! i guess its just got a great tune!
we had it on the dyno a few weeks back, couldnt get a proper hp reading as we were having trouble with wheel spin... soon as it get to 7000rpm and over 24psi it would spin so suddenly it would instantly hit the 10.700rpm rev cut.
the plan is to log it and tune it at the track.
Old Jul 5, 2008 | 04:57 AM
guamhonda16's Avatar
Default blown turbo b16
just melted a piston.the new build is going to consist of eagle rods,srp 8:5.1 cr on stock sleeves,arp head studs,.4 cometic head gasket,s2 valve train,and a turonetics t3/t4 with a 3" downpipe.we pretty much have the same bottom end but i was no where close to your time before my engine got fried.
Old Jul 5, 2008 | 07:28 PM
red02s2k's Avatar
For a 60-1 that make me wanna know where i went wrong. i would love to been able to put down that much power! very nice!!!!!!
Old Jul 6, 2008 | 12:09 AM
CRX11Z's Avatar
Default Re: (red02s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red02s2k &raquo;</TD></TR><TR><TD CLASS="quote">For a 60-1 that make me wanna know where i went wrong. i would love to been able to put down that much power! very nice!!!!!!</TD></TR></TABLE>
i was pushing it hard!, boost was 34psi.... the exhaust back pressures were way to high! at 34psi we were seeing close to 70psi in the exhaust manifold! now with the new turbo/manifold/gate its 1-1 whatever boost we run.
intake temps are cooler, exhaust gas temps are much cooler, the only think i dont like its abit laggy, so we have to rev it harder on every shift to keep it in its sweet spot!
Old Jul 6, 2008 | 08:32 AM
red02s2k's Avatar
that's nice! What kind of gas ar eyou guy's using?
Old Jul 6, 2008 | 10:26 AM
turboedc2's Avatar
C16?
Old Jul 8, 2008 | 07:08 PM
HondaCivicSiR1's Avatar
Default Re: (turboedc2)
what kind of radiator is that?also what kind of rims are those you have on there?great job on getting into the 9 sec club and your car is sick
Old Jul 8, 2008 | 07:13 PM
1FSTHATCH's Avatar
pretty nice stuff!!
Old Jul 9, 2008 | 02:53 AM
CRX11Z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 &raquo;</TD></TR><TR><TD CLASS="quote">C16?</TD></TR></TABLE>
yeh c16
Old Jul 9, 2008 | 02:56 AM
CRX11Z's Avatar
Default Re: (HondaCivicSiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of radiator is that?also what kind of rims are those you have on there?great job on getting into the 9 sec club and your car is sick </TD></TR></TABLE>
the radiator is a custom i fabricated using a pwr core, the rims are australian made Simmons and the style code is V4.
Old Jul 17, 2008 | 05:52 PM
TAP's Avatar
TAP
NICE CAR!!!!
Old Jul 18, 2008 | 01:19 PM
roadracer4life's Avatar
screw the CRX that volvo is bad ***... turbobricks FTW
Old Jul 18, 2008 | 02:34 PM
Autoworks's Avatar
Default Re: (roadracer4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadracer4life &raquo;</TD></TR><TR><TD CLASS="quote">screw the CRX that volvo is bad ***... turbobricks FTW</TD></TR></TABLE>
lol...only Sam
(that Volvo is badass though)
fusion645
Sep 20, 2010 05:29 AM
tegra2G
Jun 21, 2008 06:20 PM
warzo69
Nov 15, 2005 07:43 AM
CheezeFrog
Mar 23, 2004 10:17 PM
revhardsi
Aug 24, 2002 08:10 AM
