outer tie rod install question
Old Jul 3, 2008 | 08:04 PM
streetsold6teeny8's Avatar
Default outer tie rod install question
I needed to know how many turns to give the tie rod when installing on the inner tie rod so that the tires could be somewhat aligned?The reason I ask is because I just purchased a new rack and I need to install the new outers. I know I still need to align the car but this way there wont be so much adjusting when it comes down to aligning.. Thanks for any feedback.
Old Jul 3, 2008 | 08:39 PM
black0hatch's Avatar
Default Re: outer tie rod install question (streetsold6teeny8)
no one is going to be able to tell you how many turns to put it in. what you should have done was measure your old rack. each ride height has a different toe setting. what you can do is string it or put long boards next to the wheels and just get it close. your not gona wana drive more then to the alignment shop.
Old Jul 4, 2008 | 10:23 AM
thank u for ur feedback
Old Jul 4, 2008 | 11:33 AM
88crxvtec's Avatar
Default Re: (streetsold6teeny8)
I measured it off the old tie rods and then went straight to the alignment shop.
You can try this:
http://www.c-speedracing.com/h...t.php
Freshdot
Apr 18, 2015 06:37 PM
andybmuzik
Nov 3, 2011 03:37 PM
jdmh22luda
Aug 9, 2007 05:40 AM
Tizzlers Ep3
Aug 3, 2006 06:02 AM
crxgator
16
Apr 30, 2004 06:14 PM
