Changing me HEad question
Old Jul 3, 2008 | 07:05 PM
corchado85's Avatar
Default Changing me HEad question
Wassup guys i got a 97 accord LX so dat means non V-tec. Im about to bye a V-tec head but i realized that my accord has the coil ignition outside witch means 5 spark plugs will the V-tec head ima bye need that style of ignition to, and does it matter what year SOHC V-tec head i bye from 94-01 accord or are they different?
Help
Help
Help
And since i have the head of what can i do or get 4 more horsepower besides (Cam gear, intake, headers, exhoust, fuel rail, port polish) let me no
Old Jul 4, 2008 | 02:08 AM
GhostAccord's Avatar
Default Re: Changing me HEad question (corchado85)
FYI, The external coil ignition only has 4 plug wires and 1 coil wire. So Yes you can keep your F22B2 distributor and coil setup and use it on the VTEC head.
If you want to keep it simple stick to the 94-97 F22B1 VTEC head. 98-01 are not the same. You might have a hard time trying to fit the 98-01 F23 VTEC head on your F22 block. Don't forget that your also going to need the VTEC ECU to replace the one you have now.
As for more power, What are your goals and most importantly what is your budget? It costs money for power. Don't bother wasting your money on a cam gear and fuel rail. Unless your just going for looks, the stock parts will work well enough. If your looking for more Hp on top of what you have listed a stage 2 camshaft wouldn't hurt the pocket book too much. With a stage two cam you don't need to go out and buy an entirely new valve train. But if you are looking to spend the money. Take a look at what Bisimoto has listed for your motor. multiple cams, valve springs, retainers and teflon rocker spacers to choose from. Warning a person could get himself into financial trouble rebuilding an engine...lol
Old Jul 4, 2008 | 02:30 PM
corchado85's Avatar
Well im definately not looking for a track car but im coming from a gsr that was stolin from me to my accord and i definately dont regreat getting my accord but i wanna keep up with atleast a (Intake, header) basic LS integra even with all the extra weight in my car.
Does any1 know if a H22 tranny fit perfectly with no problem into my accord its a stock 97 LX i wanna get a good clutch, flywheel and LSD 4 now but i eventually do want a h22 swap and if i can start lil by lil i might as well get a H22 tranny and get that stuff for that any suggestions
any 1 seeling 94-97 accord stock side skirt ???????????
sonson6
Dec 11, 2007 09:56 AM
g-ride-si
13
Sep 11, 2006 01:27 PM
topmeifucan
May 19, 2005 01:33 PM
1 2 NV
Sep 14, 2002 06:09 AM
mason
Dec 11, 2001 02:33 AM
