egr and overheating problems on ls swaped crx
Old Jul 3, 2008 | 11:26 AM
1988_96hb's Avatar
Default egr and overheating problems on ls swaped crx
so im new to crx's and mine has an ls swap that giving me problems. its an 90 si with a b18a1 swap. the thermastat went out and i blew the headgasket. i replaced half of the hoses, the headgasket and the thermastat and it ran fine for a day, then the stock crx si ecu would occasionally throw code 12, which is for the egr. i looked at the egr and it isnt hooked up. is it not supposed to be in this swap? it is also leaking fluid when it sits overnight and i cant find where its leaking from. one last thing im not driving it right now because it sounds like its misfiring. im not sure what needs to be done. thanks in advance.
Old Jul 8, 2008 | 08:32 AM
1988_96hb's Avatar
Default Re: egr and overheating problems on ls swaped crx (1988_96hb)
i have new spark plugs and i have spark all the way across. any ideas?
Old Jul 10, 2008 | 10:19 AM
1988_96hb's Avatar
i found out that the hose from the pcv valve to the black box behind the block is broke. im going to fix that but could that cause my problems?
Old Jul 23, 2008 | 08:28 PM
vtecn8ive's Avatar
this should help you
https://honda-tech.com/zerothread?id=1659977
Old Jul 23, 2008 | 09:19 PM
one-cam's Avatar
what kind of fluid is it leaking???
that thread vtecn8ive posted should be helpfull
Old Jul 23, 2008 | 09:24 PM
vtecn8ive's Avatar
Default Re: egr and overheating problems on ls swaped crx (one-cam)
Not to be rude but I chose not to answer all of your questions because its all in one paragraph. If you space out the questions a bit it makes it easier to read and easier to help.
Old Jul 24, 2008 | 06:48 AM
eg6559's Avatar
i had the same problem check all water hoses every single including the ones that go to intake manifold i had that problem i had a water hose backwards and it cause my car to overheat ayy by the way do you how do vacuum lines go i a b18a1 on 1991 si and i can turn it on because their is no pressure for gas
itsnotfast
Aug 22, 2012 05:03 AM
haroldthefly91crx
Jun 7, 2008 06:14 PM
909ej195
Dec 7, 2006 09:44 PM
e jay one
Dec 6, 2006 09:58 AM
