painting tail lights?
Old Jul 18, 2002 | 11:36 PM
civic7gen's Avatar
Default painting tail lights?
if i were to paint my clear tail lights would i take it apart to paint the inside with candy apple red spray paint, or just on the surface? also, will you be able to see the reflection if you painted the outside or will it be covered and not visible?
Old Jul 18, 2002 | 11:39 PM
Accord94DX's Avatar
Default Re: painting tail lights? (92accordex)
appearance forum will know.
Old Jul 19, 2002 | 05:24 AM
greensleeper's Avatar
Default Re: painting tail lights? (Accord94DX)
I tried this once. I wanted to color match the upper red portion of my 95 taillaights to the cars paint since its nothing but a reflector. But a week later it all came off when I washed my car. Good thing too. It looked gay as hell.
But it was probably not the right paint or anything like that so just do some research. I know there paint out there that you can 'smoke' your lenses with and I'm sure if you look hard enough you'll find other colors.
Old Jul 19, 2002 | 05:27 AM
YeuEmMaiMai's Avatar
whenever you paint plastic you will need a special primer that acts like a bonding agent since plastic does allow paint to really stick to it....
Old Jul 19, 2002 | 06:00 AM
96 SOHC VTEC's Avatar
Default Re: painting tail lights? (YeuEmMaiMai)
I painted my stock Civic tailights a few years ago. I just sprayed a few coats of regular primer on, let that dry, and then began with Testors Transparent Candy Apple Red spray paint. After that was done I used a couple coats of clear coat to finish it off. The paint stayed on for over a year before it needed a new coat.
Old Jul 19, 2002 | 09:27 PM
aaronic's Avatar
Default Re: painting tail lights? (96 SOHC VTEC)
1primer
2transparent candy apple red spray paint
3clear coat
Old Jul 19, 2002 | 09:31 PM
b18bEG's Avatar
after a while it will all start to fade, and then it will look like you have pink taillights. I had this probmlem. just spen the $ and buy some..
t-town_ep
Jul 3, 2007 03:45 PM
mordezmoncou
14
May 30, 2005 03:49 PM
jazz1320
May 2, 2005 09:59 PM
stockegsix
Dec 10, 2002 05:09 PM
raph
Mar 25, 2002 06:39 AM
