problem after problem
Old Jul 2, 2008 | 11:19 PM
EF-junkie's Avatar
Default problem after problem
Hey guys i just swap a b16 with an ls tranny and a brand new clutch cause im getting ready for turbo. but i was wondering why my car feels like the motor is struggling until vtech hits. also i took a look at changing my axles and found out that the frame were the rack'n penion is bolted on is cracked bad. i dont know if i should weld it or if i weld it will get worse in the long run
this sucks to cause every time i fix one problem another one shows up
Old Jul 3, 2008 | 05:21 AM
IndySporty's Avatar
Default Re: problem after problem (EF-junkie)
You should check your timing (belt and distributor) and converting to OBD-1 will make your car a lot more responsive, as well as easier to tune when you go turbo. You should look into getting another rear cross member to replace that cracked one. It can be changed out in one day if you know what you're doing.
Old Jul 10, 2008 | 02:36 AM
EF-junkie's Avatar
Default Re: problem after problem (IndySporty)
i already converted everything. but good lookn on the info
Old Jul 10, 2008 | 11:22 AM
FastEg6's Avatar
Could be that your running an Ls tranny. Check the timing, see if it's off.
Old Jul 10, 2008 | 11:31 AM
TOO MUCH TORQUE's Avatar
LS tranny is too long for b16.
airikkCRX
Apr 23, 2010 12:55 PM
Capsule Kid
Apr 4, 2006 08:50 PM
corey's96GSR
Jun 6, 2004 08:37 PM
CyrusDrum
May 2, 2004 08:20 AM
mini-v-si
Mar 17, 2004 06:29 AM
