wiring radiator fan
if its the stock fan and all the wireing is stock you can just conect the 2 wires from the fan switch on the engine harness then it will come on when ever the key is in the on spot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KDvtec5757 »</TD></TR><TR><TD CLASS="quote">ok but where is the fan switch</TD></TR></TABLE>
do you have an 88-89 crx
if you search you will find it's been covered already...i would do it for you but i fixed my fan about 2 years ago when i got the car. you could also get a haynes or chilton's manual, it's the best 20 bucks you'll spend.
as an aside, i really don't think you want to wire your fan up to be on all the time. it will eat amps and gas and make the car run richer longer while it warms up. whatever is wrong, fix it...it will be just as easy as what you are trying to do. probably just a broken wire, relay or switch. but if you insist on doing it the wrong way, at least make sure you use a relay
JDMsalinger
Aug 12, 2013 06:04 AM
