Spare Tire
Old Jul 2, 2008 | 04:00 PM
bopbop93030's Avatar
Default Spare Tire
Ok.
I have upgraded my wheels and tires to 17's now should I remove my spare tire or should I keep it there?
Will it still work 1 15 and 3 17's just in case there is a flat?
Thanks
Old Jul 2, 2008 | 04:20 PM
TunerN00b's Avatar
Default Re: Spare Tire (bopbop93030)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bopbop93030 &raquo;</TD></TR><TR><TD CLASS="quote">Ok.
Thanks</TD></TR></TABLE>
Lols.
Your spare wasn't the same size as the rest of the stock tires anyway. Keep the spare.
Besides, even with a "full sized" spare, if you purchased the correct tires for your 17s, then the outer diameter of the tires should be the same, regardless of the wheel size.
Old Jul 3, 2008 | 02:06 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Spare Tire (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Your spare wasn't the same size as the rest of the stock tires anyway. Keep the spare.
Besides, even with a "full sized" spare, if you purchased the correct tires for your 17s, then the outer diameter of the tires should be the same, regardless of the wheel size.</TD></TR></TABLE>
lonestar55
Nov 26, 2007 09:41 PM
hellasexyteg
Mar 27, 2007 01:41 PM
IamN00b
Jan 5, 2007 07:41 AM
schwingding
Nov 21, 2005 10:13 PM
daft
Jul 7, 2005 12:10 PM
