Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
95 integra front wheel bearing removal?
Old Jul 2, 2008 | 03:35 PM
crv-techu's Avatar
Default 95 integra front wheel bearing removal?
what do i need tools wise to remove wheel bearings from front spindle.i've never done this before i was wondering what methods are used to accomplish this in your garage at home
Old Jul 3, 2008 | 12:30 PM
Splaturn's Avatar
Default Re: 95 integra front wheel bearing removal? (crv-techu)
http://wiki.answers.com/Q/How_...ccord
Or do a search...
Old Jul 15, 2008 | 03:28 PM
rice a roni's Avatar
wrong forum but ok anyways...
take the axle nut off.
put on a slide hammer. slide hammer the hub out
now, take off the nut thats holding the it to the upper and lower control arms and take it to a shop
have them press out the old on and press on the new one. they might charge you a little but dont fret.
now have them press on the hub into the bearing and then install again.
Old Sep 1, 2008 | 09:19 PM
Japostol78's Avatar
i agree with the other guy....remove the hub...take it to a shop n have them press in the new wheel bearing....OEM honda wheel bearings cost alot but if you dont mind going with a non oem one...you can get them at auto stores for 35-40 bucks...(so i've seen)...i need to change my wheel bearing on the drivers side...i'm going to go with the non OEM bearing...OEM bearings are too pricey for me...but if you wanna try doing it yourself...check this DIY article out... https://honda-tech.com/zerothread/1996133..hope this helps...
^XpLiCiTxX^
Oct 18, 2008 01:44 PM
96_9c1
Mar 15, 2008 05:34 AM
jaskuloski97sh
Dec 4, 2007 06:18 PM
wrx'n you
Sep 16, 2006 11:30 AM
Archie_G
Nov 18, 2003 01:39 PM
