b16a conversion???????????
Old Jul 2, 2008 | 02:32 PM
mikebell_89's Avatar
Default b16a conversion???????????
hey everybody.i have a 88 ef civic with a sohc carb peice.ive got a b16a and gear box in my garage.how much work would be in it to put this in aprt from engine mounts???
any help would be good
cheers
mike.
Old Jul 2, 2008 | 03:47 PM
hotrod99's Avatar
Default Re: b16a conversion??????????? (mikebell_89)
you need shift linkage,motor mounts,axles,ecu,and you have to add a few wires as shown here----> https://honda-tech.com/zerothread?id=2266663 ohh and you will most likely have to hit in the frame alittle to clear the alternator.
Old Jul 2, 2008 | 06:32 PM
zrickety's Avatar
Default Re: b16a conversion??????????? (hotrod99)
it's really straight forward if you have the parts listed above...probably get it done in a weekend. as long as it's obd0, b16a1, if it's newer you'll need a jumper harness at least
Sammy_Po
Mar 15, 2006 08:04 PM
