will 96 mt ecu work for a 98?
Old Jul 2, 2008 | 12:30 PM
THEDirtyDseriesWOOT's Avatar
Default will 96 mt ecu work for a 98?
will a 96 accord manual ecu work for a 98 manual accord both with f22's
im asking this because of the immobilizer chip? do the 96 have immobilizers?
im doing a auto to manual swap on a 98 coupe and the local u--pull it has a 96 manual ecu ?? will it work and will i have to do any wiring changes cause of the ecu
i already wired the car for the manual swap and it drives with the auto ecu, but its in limp mode cause auto ecu please help fast
Old Jul 2, 2008 | 04:50 PM
bump
Old Jul 2, 2008 | 06:28 PM
GhostAccord's Avatar
Default Re: (THEDirtyDseriesWOOT)
Are you sure your 98 Accord has an F22? Must be a swap, I'm pretty sure most 98-02's came with the F23's. If you do have an F22 is it VTEC or Non VTEC? You will need to get the M/T ECU that matches the engine. No the 96 Accord ECU's did not use the immobilizer.
Dominicandude
Engine Management and Tuning
Nov 9, 2012 03:17 PM
Ser1N
Oct 4, 2007 01:39 PM
accordguy95
Mar 13, 2004 01:58 AM
