Ready for Smog????
Old Jul 2, 2008 | 07:36 AM
bseries637's Avatar
Default Ready for Smog????
Just about ready to smog my gsr. Fixed the CEL and replaced the little filter on top of my vc to the breather hose. But small amounts of smoke is coming out from the back of my exhaust. Not a lot but enough to notice a few puffs here and there. Is this something I should worry about or anything else? smoke looks black. Because I bought the car a few weeks ago and i'm clueless on what it is capable of. Everything pretty much looks stock except for the NGK spark plug wires and no AC and it looks like it has 2.5 piping. any advice before I actually go to the shop would help. thanks
Old Jul 2, 2008 | 07:49 AM
all-mtr-teg's Avatar
Default Re: Ready for Smog???? (bseries637)
Have them do a pre-test to see where your car's emission numbers stand. That way they will tell you if you car will or won't pass the actual smog test. Because if your numbers are too high, they will label your car as a gross polluter and then you will have to take your car to a test only shop.
Taken from the CARB website
Black Smoke: Excessive or too much black smoke from the muffler is almost always due to a rich fuel mixture and will produce high CO, and consequently high HC during the smog check or inspection.
White Smoke: A vehicle emitting excessive white smoke from the exhaust may have a burned or blown head gasket. A blown head gasket may cause overheating and high NOx emissions. Most often the level of NOx produced will be twice the allowed limit, rendering your vehicle as a gross polluter or HEP.
Old Jul 3, 2008 | 08:56 PM
typeRmike055's Avatar
Default Re: Ready for Smog???? (all-mtr-teg)
if your car is smoking thats an automatic fail the B.A.R. just started a new visible smoke test
Old Jul 3, 2008 | 09:15 PM
Default Re: Ready for Smog???? (typeRmike055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeRmike055 &raquo;</TD></TR><TR><TD CLASS="quote">if your car is smoking thats an automatic fail the B.A.R. just started a new visible smoke test</TD></TR></TABLE>
That's right, I've even seen billboards on the freeway to report cars that are smoking and gross polluting the air. That's actually a good idea cause I hate driving behind these ***** in traffic. We'll see if they started getting stricter on public transportation and diesel vehicles.
Old Jul 3, 2008 | 09:18 PM
is your car a test only or regular smog?
Old Jul 3, 2008 | 11:04 PM
jcidio's Avatar
check ur timing. it should be at 16 +/- 2. also if u have been running rich for along time, ur cat has probably gone bad so u might wana change it. 2.5 carsound cat is like $70 on ebay btw. also do major maintenance, oil, plugs, cap rotor. gl w te test bro
Old Jul 8, 2008 | 06:52 AM
bseries637's Avatar
Default Re: (jcidio)
I believe it is a smog. not test only. Because all I'm doing is transfering a title from the previous owner to me.
hatch_
11
Feb 13, 2007 12:08 PM
Kangolbrand
Jul 12, 2006 02:16 AM
Unlimitationz
May 6, 2005 03:20 PM
RegRedTeg
Oct 18, 2002 11:14 AM
