AUTO TO MANUAL SWAP
Old Jul 2, 2008 | 06:43 AM
Stillo's Avatar
Default AUTO TO MANUAL SWAP
first off i know im goin to be told to search and i have
i am making this thread to clear up what ive searched
i have a 96 4 door ls
and i recently picked up a b16 lsd trans (cable)
from what i have picked up im going to need
-shift linkage (any b series i believe)
-clutch pedal (out of a DA? only?)
-brake pedal
-starter
-ecu
-clutch
-flywheel
-clutch cable
-trans torque mount
-hasport auto to manual mount (unless i relocate stock mount bracket)
i still havnt found out how to bypass the brake to shift lock
and how will i get the reverse lights to work?
if i am missing anything or there is anything i dont need that i have listed that anyone can tell me ill appreciate it greatly
to h-t
Old Jul 3, 2008 | 03:01 PM
Stillo's Avatar
Default Re: AUTO TO MANUAL SWAP (Stillo)
if im not mistaken dont i also need manual axles?
Old Jul 3, 2008 | 06:16 PM
lsvtecboi'95's Avatar
you need a manual halfshaft, a manual rear T bracket for the B16tranny ($60 at honda),
Old Jul 6, 2008 | 06:57 PM
Stillo's Avatar
Default Re: (lsvtecboi'95)
thanks ill keep that in mind, any thing else h-t?
Old Jul 6, 2008 | 10:54 PM
CompanyFlow's Avatar
I seriously think it would be cheaper and a lot more reliable for you to just buy a 4 door GSR.
Old Jul 6, 2008 | 11:54 PM
Apathy47's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stillo &raquo;</TD></TR><TR><TD CLASS="quote">thanks ill keep that in mind, any thing else h-t?</TD></TR></TABLE>
these links may help you too:
AT to MT Parts List:
https://honda-tech.com/zerothread?id=273253
https://honda-tech.com/zerothread?id=1316692 (for Civic EG, but the info are similar.)
a detailed DIY:
https://honda-tech.com/zerothread?id=1337459
Good luck.
Old Jul 9, 2008 | 07:51 AM
Stillo's Avatar
Default Re: AUTO TO MANUAL SWAP (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">I seriously think it would be cheaper and a lot more reliable for you to just buy a 4 door GSR.</TD></TR></TABLE>
Maybe so but that is not an option right now and
i found this car with low miles and it was stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apathy47 &raquo;</TD></TR><TR><TD CLASS="quote">
a detailed DIY:
Good luck. </TD></TR></TABLE>
thanks for the info
tbud454
Apr 13, 2020 09:53 PM
mysuperslowej1
Nov 10, 2013 02:05 PM
zurud
Oct 16, 2009 12:46 PM
Hal9000
12
Nov 24, 2008 05:16 PM
wannab20hatch
Aug 21, 2002 07:03 PM
