just installed new injector plugs .. now i have a weird problem
Old Jul 2, 2008 | 04:59 AM
pjr710's Avatar
Default just installed new injector plugs .. now i have a weird problem
i just installed my dsm injector plugs like 2 days ago. i kept my stock plugs also b/c i'm runnin stock injectors right now.. so i have both plugs hooked up.
anyway, the car runs fine, but the problem is this: when i turn the key to start the car, the ignition doesnt kick in at the same time it used to. for instance, before i did this, when i would turn my key all the way .. the car would fire right up. now when i do it, there is like a second or 2 delay then it fires up. its almost liike my battery is dead for 2 seconds .. then the car startsup. any idea why this happens?
last nite i really notied it .. and i thought it was cuz i was low on gas, so i filled it up and it was workin good.. but now again this morning it does it again. i mean the car is fine .. but i just wonder why its doin this .. and if it should be or not. the only deduction i have made so far is that since htere are 2 injector plugs where there should be one, maybe the electrical current goes to one first ... then the other .. and this results in the delay.. i dunno .. what are your opinions?
Old Jul 2, 2008 | 09:23 AM
MadScientistMatt's Avatar
Default Re: just installed new injector plugs .. now i have a weird problem (pjr710)
Unless you shorted something out in the injector harness the two plugs shouldn't be an issue since only one set actually has current through them. I suspect you knocked something else loose in the wiring harness.
Old Jul 2, 2008 | 12:01 PM
pjr710's Avatar
Default Re: just installed new injector plugs .. now i have a weird problem (MadScientistMatt)
everything works perfectly.. car .. lights .. boost gauge. but liike just now .. i started my car and it started just fine. but other times its doing what i mentioned above .. i dont know why
bambbrose
Nov 9, 2008 09:56 AM
boosted k20
Jan 18, 2008 02:33 AM
the1337couch
May 3, 2007 09:32 PM
DOHCon15s
Dec 3, 2003 06:11 AM
Buckshot
Nov 7, 2002 08:16 AM
