door guards - how do you remove and replace clips.
89 crx dx
<U>door guards - how do you remove and replace clips.</U>
i have been using the wrong name -
door exterior <U>side panels</U> - how do you remove and and install.
blkjak -
Modified by blkjak at 10:23 AM 7/6/2008
Modified by blkjak at 10:30 AM 7/6/2008
blkjak -
From: Close to West Chester, PA, United States of America
Go to junkyard.
Practice.
Apply at home.
Hopefully not ruining something from the yard. If so, buy something from them to make up for it.
Practice.
Apply at home.
the best that i can tell you is that you WILL brake atleast one cuz you can't get to all of the tabs, and they aren't cheap, i think i payed like 15 bux for like, 3 at honda of gresham. my *** hurt that day. any ways, the best way i see to remove the trim is to remove the interior of the car and depress the plastic tabs on the back side of the trim (from inside of the car) and then push forward. i can post some pix of it if you'd like
DCRB got it right. Its a simple clip. Remove the interior door panel & the plastic sheet beneath it. Then you'll see the clips, they are black with two flexible tabs on the top & bottom. Use needle nose pliers & compress both the tabs at the same time, & push the the clip forward.
Using this method I didnt break a single clip, & it took a relatively small amount of time overall.
alex1321
12
Jan 25, 2013 08:59 PM
truckhigh
10
Jun 7, 2005 06:09 AM
verseone
Sep 11, 2003 07:41 AM
