What Turbo kit did you use?
None of the above, im puting my own together
Rob
Rob
[Modified by W.ZeroB18C1T, 8:05 AM 7/19/2002]
In a custom kit, what would you need to buy? its cheaper right?
www.homemadeturbo.com<----allot of good info for the "thrifty" tuner
Rob
you can make it cheaper but your going to pay for it in the long run. if you cant afford to drop all the cash at once, just slowly peice it together. I wouldnt recomend going half *** on this. It is going to end up costing me more than a kit probably. but you can do it cheaper through sources like ebay and such.
Rob
Rob
good luck and let us know what u did.
[Modified by W.ZeroB18C1T, 4:45 PM 7/22/2002]
not to start an arguement, but a lot of the guys that say they go custom kits use pieces from different turbo kits and find the other parts used... drag, revhard, f-max, etc... so is this REALLY custom? hehe
Custom route:
It's being built starting from a Max-Rev manifold, turbo, and DP and should be installed by the end of the year.
Once that is working I'm switching the turbo and boost control out for a special project I'm working on.
[Modified by SLPR, 9:27 AM 7/25/2002]
ridnmyhonda
Mar 11, 2003 05:05 PM
ITRfaithful
Jun 30, 2002 08:31 PM
