long scratch on read window 97 ex 2dr.
Old Jul 2, 2008 | 12:40 AM
cpgottabuh's Avatar
Default long scratch on read window 97 ex 2dr.
i have a nice long scratch on my rear window.. im gonna be doing tints this week and i dont want that to be there when the tint is put on.. anyone have any methods or advice on this? if i can wet sand it out somehow or something like that.. thanks..
Old Jul 2, 2008 | 02:29 AM
hotrodaccord's Avatar
Default Re: long scratch on read window 97 ex 2dr. (cpgottabuh)
A scratch? you can't wet sand glass....Wet sanding glass will give you a fogged look and pretty much look like @ss. you can fill it. It's basicaly the same stuff you use to fix a crack in your windshield. is the scratch on the inside or outside. How long is it? Which direction doesthe scratch go You have an ex so you must have a rear defroster... what about the radio antenna do you have a mast on the quarter panel... if not it's in your back window. I would call a profesional and have them come out and look at it. most insurance companies will cover glass repair/replacement if you have full coverage. If the scratch isn't deep and on the inside you might beable to hide it when they install the tint. might look like the defroster lines if the scratch runs parallel with them.
Old Jul 2, 2008 | 05:56 AM
TheMuffnMan's Avatar
* B A N N E D *
Default Re: long scratch on read window 97 ex 2dr. (hotrodaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrodaccord &raquo;</TD></TR><TR><TD CLASS="quote">A scratch? you can't wet sand glass....Wet sanding glass will give you a fogged look and pretty much look like @ss. you can fill it. It's basicaly the same stuff you use to fix a crack in your windshield. is the scratch on the inside or outside. How long is it? Which direction doesthe scratch go You have an ex so you must have a rear defroster... what about the radio antenna do you have a mast on the quarter panel... if not it's in your back window. I would call a profesional and have them come out and look at it. most insurance companies will cover glass repair/replacement if you have full coverage. If the scratch isn't deep and on the inside you might beable to hide it when they install the tint. might look like the defroster lines if the scratch runs parallel with them. </TD></TR></TABLE>
1) Yes/No on the wet sand, you can but without getting baller sandpaper you can't feasibly do it at home.
2) All the Accords have a rear defrost (DX &gt; EX)
3) The antenna doesn't matter if you're worried about that with tint, my DX has it in the rear window and both the defrost and antenna work fine
4) I'd just leave the glass alone personally and tint it. You could try to fill it, but it could turn out looking odd. You could also replace it but that's costly.
mail4hemanthr
Paint and Body
May 31, 2013 04:13 PM
surfnaked619
14
Jan 7, 2011 07:21 PM
zero708970
Dec 1, 2008 01:09 PM
kap_x
Nov 21, 2004 03:22 PM
shauniewalnuts
Dec 7, 2003 07:45 AM
