Turn signal flasher question
Old Jul 2, 2008 | 12:00 AM
Nihilus's Avatar
Default Turn signal flasher question
I can legitimately say I went through ALL the archived stuff and didn't find this issue. My turn signal flasher does not turn off after making a turn left or right. My signals work fine it's just that I have to click the lever off manually each time I make a turn. It's pretty annoying and hopefully I'm just missing something basic. I have OEM steering wheel with no modifications to the steering collum [sic](?). Any ideas guys?
Old Jul 2, 2008 | 09:18 AM
hotrod99's Avatar
Default Re: Turn signal flasher question (Nihilus)
Bad relay or flasher. I'd start there, then check out the multifunction switch itself if changing the relay or flasher doesn't help.
Old Jul 2, 2008 | 10:30 AM
wiZCo's Avatar
Stouts 'n' Scotch
My guess is a bad MF switch. If the flasher or relay were bad you'd just be getting a solid light or it wouldn't work at all.
Old Jul 2, 2008 | 11:03 AM
Nihilus's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">My guess is a bad MF switch. If the flasher or relay were bad you'd just be getting a solid light or it wouldn't work at all.</TD></TR></TABLE> MF switch?
Old Jul 2, 2008 | 11:05 AM
DCRB's Avatar
Default Re: (Nihilus)
He means multi-function switch. aka the turn signal switch.
Meraut
Mar 11, 2013 06:34 AM
ls19integra95
Feb 19, 2008 09:48 PM
professorman
May 18, 2006 10:21 AM
dreams190
Apr 1, 2005 07:00 AM
pablo_max
Nov 12, 2002 04:02 PM
