anoying useless beeping wont stop....HEELLLPP ME PLEASE.
ok so everytime i start my car evrything is fine but after i start driving 5 minutes later or so it starts to beep like hell and i start punching the dashboard cause of the frustration...i just want it to stop.....if it can't be helped is there a fuse or wire i can cut to make it shut the f-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">Hahaha There is a speaker in the ICM and is it a beep that represents high beams on, or key in ignition with car off and door open?</TD></TR></TABLE>
YEESS that it.... can I remove it?
...where is the ICM(total noob
Sounds like an ICU (Integrated Control Unit) problem. Do you also have issues with your intermittent wipers not working or working randomly? Does your rear defroster work? Do you (not)have the door-ajar chime or chime when the key is left in the ignition? If you do, check this thread out on G2IC.com
http://g2ic.com/forums/showthread.php?t=127170
My old DA had that problem, swapped out the ICU though instead of following the repair DIY. BTW, the ICU is located on the back of the interior fuse box.
Another note: Although the author of that DIY only stated that the ICU issue appeared '90-'93 Integras and '90-'93 Accords, I had the same ICU problem in my '95 Integra and fixed it the same way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchi »</TD></TR><TR><TD CLASS="quote">Sounds like an ICU (Integrated Control Unit) problem. Do you also have issues with your intermittent wipers not working or working randomly? Does your rear defroster work? Do you (not)have the door-ajar chime or chime when the key is left in the ignition? If you do, check this thread out on G2IC.com
Another note: Although the author of that DIY only stated that the ICU issue appeared '90-'93 Integras and '90-'93 Accords, I had the same ICU problem in my '95 Integra and fixed it the same way.</TD></TR></TABLE>
thanks man I located the icu and quieted the fuocker down...no more beeping..yay
alexthegrinch
Sep 17, 2022 05:40 PM
