bike wont start
Old Jul 1, 2008 | 06:23 PM
hedtrip's Avatar
Default bike wont start
im pretty new to bikes.
i have a 95 cbr600 & it's pretty hard to start & when it does start it will run for a few min's. i took it around the block & it died & wouldn't start back up again. unless i let it set for a lil while. just like a main relay would on a honda civic. anyone else have this prob?
Old Jul 1, 2008 | 06:38 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: bike wont start (hedtrip)
check ur battery voltage and if thats fine ur carbs might need to be cleaned.
Old Jul 2, 2008 | 07:17 AM
hedtrip's Avatar
battery is good.
& whats the best way to clean the carbs ?
Old Jul 2, 2008 | 08:23 AM
bad-monkey's Avatar
Default Re: (hedtrip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hedtrip &raquo;</TD></TR><TR><TD CLASS="quote">battery is good.
& whats the best way to clean the carbs ?</TD></TR></TABLE>
let em sit in a solution of water and simple green for a day, or cook em under very low heat in the same solution.
you'll need to replace all the gaskets in the carb--might wanna pick up a F3 manual.
you're also gonna wanna get the carbs sync'd after you do it.
Old Jul 2, 2008 | 08:34 AM
.RJ's Avatar
.RJ
Default Re: (bad-monkey)
Dont cook the carbs. Just let them soak, after removing ALL the jets.
On the F3 keihins there's no gaskets to replace other than the float bowl gaskets, and most of the time you can reuse those with no issue.
I wouldnt immediately bank the problem on the carbs though. Maybe the fuel tap isnt pulling fuel into the carbs (its vacuum operated). Are you sure there's enough gas in the tank as well?
Old Jul 2, 2008 | 10:17 AM
hedtrip's Avatar
yes there's plenty of gas. & the pump is working.
Old Jul 2, 2008 | 10:26 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hedtrip &raquo;</TD></TR><TR><TD CLASS="quote">yes there's plenty of gas. & the pump is working.</TD></TR></TABLE>
There's no fuel pump, just a vacuum operated fuel tap.
Old Jul 3, 2008 | 05:10 AM
hedtrip's Avatar
what about a main relay? do they have one?
Old Jul 3, 2008 | 05:15 AM
.RJ's Avatar
.RJ
The bike wouldnt start at all if the relays that turn the ignition/ecu on were broken.
Its not a civic...
Hatchless96
Honda Motorcycles
Sep 5, 2009 10:55 AM
JSJ EG6
Honda Motorcycles
Jun 1, 2007 04:38 AM
9civic5
Honda Motorcycles
10
Dec 14, 2006 01:22 PM
mookie
Honda Motorcycles
Oct 24, 2005 09:04 AM
CWLos
Honda Motorcycles
Sep 13, 2005 08:07 PM
