My civic redlines at 5K need help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERIC1 »</TD></TR><TR><TD CLASS="quote">Never mind it has no light bulb so IDK</TD></TR></TABLE>
go buy a bulb and check because thats what happen to my friends B20. i think it's your ECU
i had the same problem at different rpms... i was given the ckp code for the crank position sensor and even after changing that still had the problem.. ended up being my ecu switched that out everything was good
I had that problem after my b16a swap too, except mine hit rev-limiter at about 4K... it turned out that it was my obd2-obd1 conversion harness... i got a new harness and problem solved!
My old harness was in really bad shape, it had been spliced back together in multiple spots... so i dont know if that would be your problem too, but its worth checking into...
check valve timing.
put a new timing belt on it and put it in time again, mine was doing the same thing, and i just replaced the timing belt and put it in time, runs like a champ
