Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
extended wheel studs install
Old Jul 1, 2008 | 05:09 PM
elitezdc5's Avatar
Default extended wheel studs install
can you install extended wheel studs without separating the wheel bearing and taking off the knuckle (peice that studs press into) or you must take off the knuckle to get the studs off? im installing extended wheel studs when i get them end of the week.
Old Jul 1, 2008 | 05:11 PM
toyomatt84's Avatar
Sanji
Default Re: extended wheel studs install (sspem2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sspem2 &raquo;</TD></TR><TR><TD CLASS="quote">can you install extended wheel studs without separating the wheel bearing and taking off the knuckle (peice that studs press into) or you must take off the knuckle to get the studs off? im installing extended wheel studs when i get them end of the week.
You'll have to pull the hubs. There's not enough clearance to get the studs by the knuckle.
I think this was asked a while ago, but meh', whatever.
Old Jul 1, 2008 | 05:17 PM
elitezdc5's Avatar
Default Re: extended wheel studs install (toyomatt84)
ehhh this sucks. the bearing are like 80 bucks a piece. dam brembo bbk. thanks matt
qpzm12
May 29, 2011 11:01 PM
SlowB16
Jun 11, 2008 07:00 AM
Si Erik
Jan 25, 2004 08:51 PM
GreenR
Sep 12, 2003 01:49 PM
