knockin sound(vdeo)
Is there a loss of power? Almost sounds like a valve tapping something but i dont know why it would do it at a certain rpm. Are you sure its not the heat shield vibrating?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">Is there a loss of power? Almost sounds like a valve tapping something but i dont know why it would do it at a certain rpm. Are you sure its not the heat shield vibrating?</TD></TR></TABLE>
no,the car runs fine, i checked the shield but the screws are in place and firm.it sounds like something is lose but i don tknow
sounds like a bad exhaust manifold gasket. if I were you I would remove the heat shield and with some rpm put your hand around the gasket and see if you can feel air coming out of gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 »</TD></TR><TR><TD CLASS="quote">sounds like a bad exhaust manifold gasket. if I were you I would remove the heat shield and with some rpm put your hand around the gasket and see if you can feel air coming out of gasket.</TD></TR></TABLE>
i love you man..no homo..it was the gasket.
sweet, I am glad you found it. it was kind of hard to tell over those videos but I got a turbo setup and have blown out a few so I should know what they sound like.
