Custome Crx Rear Cross Memebr Needed
Old Jul 1, 2008 | 04:51 PM
gs1gsr's Avatar
Default Custome Crx Rear Cross Memebr Needed
Ok well this is the issue. Im having issues with bending rear cross members so bad in my crx that it will pull my shift linkage out of the rubber boot that hold the linkage up. This is the second one in two trips to the track. The car has Hasport Motor mounts with the hardest rubber they offer for drag racing and Full Race front cross memeber. The car makes crazey torque and that not really helping. What are some idea that will eliminate this issue. I really cant wait for some ideas i'm ready to kill the car.
Old Jul 1, 2008 | 05:44 PM
Jared's Avatar
you need to build a front engine mount for the car. the three mount setup is what kills the rear crossmembers on efs with a lot of torque.
Old Jul 1, 2008 | 09:37 PM
speeddave's Avatar
Default Re: (Jared)
i cant contribute to your solution, but i am interested in your problem what kind of hp/torque are you making? i've heard a few people compain about this in the ef chassis.
Old Jul 2, 2008 | 09:39 AM
Bakeoff's Avatar
Have you thought about dropping the subframe and stitch welding and reinforcing it?
Old Jul 2, 2008 | 05:12 PM
gs1gsr's Avatar
Default Re: (Bakeoff)
Well its making 650 to the wheels and 415 ft torque
Old Jul 2, 2008 | 05:55 PM
Jared's Avatar
Default Re: (gs1gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gs1gsr &raquo;</TD></TR><TR><TD CLASS="quote">Well its making 650 to the wheels and 415 ft torque</TD></TR></TABLE>
then you need at least 4, maybe 5 engine mounts. the single rear mount wont cut it. trust me, i speak from experience.
Old Jul 2, 2008 | 06:58 PM
gs1gsr's Avatar
Default Re: (Jared)
do you have some picture of were else you might make a motor mount
Old Jul 2, 2008 | 07:13 PM
downest's Avatar
Make a mount off your traction bar, that's the easiest solution. You could also "upgrade" your mounts to solid aluminium inserts which HASport offers (we have them in our turbo B16 CRX).
Old Jul 3, 2008 | 06:28 PM
Jared's Avatar
solid aluminum works. the solid front mounts ive used are from traction bar or tow hookarea to former ac compressor bolt holes or to transmission works very well.
Old Jul 3, 2008 | 09:37 PM
Mr.E.G.'s Avatar
here are some examples i've seen on honda-tech that i liked so much that i saved them to my hard drive to serve as inspiration.
i want to make it abundantly clear that I am not taking credit for any of this.
Those first three were made by tony palo. the last is obvious enough.
i'd suspect with either of those setups the engine isn't torquing fvcking anywhere.
also, if tony or nrg tech would like me to remove these pics, suck my *****. you shouldn't have put them on the interweb if you didn't want people to learn from them.
Old Jul 4, 2008 | 07:15 PM
88ED8's Avatar
Default Re: Custome Crx Rear Cross Memebr Needed (gs1gsr)
Interesting...
Old Jul 5, 2008 | 03:39 PM
gs1gsr's Avatar
Default Re: Custome Crx Rear Cross Memebr Needed (88ED8)
Nice thanks for the pics i think i can take form all of them and come up with an idea for a fab guy here.
Old Jul 11, 2008 | 07:02 PM
thumper64's Avatar
When all else fails, hillbilly engineering prevails.
Just keep adding more metal until it's strong enough. Beef up the cross member, and reinforce anything connecting to it. Brace the hell out of the engine.
Old Dec 17, 2008 | 06:53 PM
gs1gsr's Avatar
Ok well i did a little work to the car let me know what you guys think.
http://viewmorepics.myspace.com/inde...ageID=50263252
http://viewmorepics.myspace.com/inde...ageID=50263012
http://viewmorepics.myspace.com/inde...ageID=50355735
http://viewmorepics.myspace.com/inde...ageID=50384298
Old Dec 17, 2008 | 09:57 PM
m R g S r's Avatar
cant see any of em. . .
Old Dec 18, 2008 | 07:38 AM
gs1gsr's Avatar
Sorry try this.
gs1gsr
Welding / Fabrication
31
Apr 2, 2014 05:21 AM
gs1gsr
Suspension & Brakes
Jul 19, 2008 07:34 PM
gs1gsr
Jul 5, 2008 03:44 PM
efgarage
Nov 17, 2005 05:12 PM
RACERDAN
Oct 25, 2003 02:36 PM
